04-20-2015, 12:09 PM | #1 |
Need some help with my K10 Springs
I have an 85 K10, shortbed, stepside. It's a very original truck with original springs. But now it needs shocks. After much deliberation I ended up getting some RS9000's. BTW this truck does not have the quad shocks.
I installed one of the front 9000's and I noticed it only had about 2-3" of compression travel in the rod. The body seems too long. I took it off and figured I'd call my dealer today about it. Before I call them I thought I should measure the distance between the bump stop and the axle. That measurement was about 2". The springs have the negative arch, but I was under the impression that is normal. It doesn't seem low, and regardless of the shocks, I like the ride. I like the stock look too, so I really don't want to lift it. So my question is, what should I expect on my K10 between the bump stop and the front axle? Are these springs sagged? Or are the shocks/springs ok with that little bit of compression travel on a mostly street truck? |
04-20-2015, 05:38 PM | #2 |
Re: Need some help with my K10 Springs
They may be sagged a little. After 30 years, I'd expect it. IIRC, my old K-20 only had 2-3".
Don't know about your shocks. I believe I installed replacement Monroe's on mine as it was a work truck. The negative arch is normal. I'm sure more knowledgeable folks will be by.
'86 C-30 dually, 454/tbh400 '73 K-20 350/350/205 (sold ) I'm kinda like duct tape- no real purpose, but handy to have around. |
