Old 08-30-2003, 10:43 PM   #1
fast67chevy2002
Dad's little helper
fast67chevy2002's Avatar
Question will a camaro rear end work?
I have a disc brake rear end that I bought for my '78 camaro, but I sold the car and I was wondering if that rear end would work on my 67 swb. Is it too short or too long, or can I take the discs off of that and put it on my rear end I have now. the rear end I have now is 3:73 five lug. If someone could help that would be great. thanks
fast67chevy2002 is offline   Reply With Quote
Old 08-30-2003, 10:50 PM   #2
CoryM
It will be too narrow and the spring perches will be different (trucks use a wider spring). You *might* be able to unbolt the brake stuff off the TA rear and bolt it on the truck if you get the right rotors. THe truck will have a 5x5" bolt pattern where the TA will have a 5x4.75" pattern. Maybe a pair of 71-73 front discs on back? Not sure.
Good Luck.
CoryM
1970 heavy duty C-10 fleetside sport truck. Vancouver B.C. Canada
http://www.geocities.com/chevroletc1070
"Take up our quarrel with the foe:
To you from failing hands we throw
The torch; be yours to hold it high."
Lieutenant Colonel John McCrae, Canadian Army
CoryM is offline   Reply With Quote
Old 08-30-2003, 11:03 PM   #3
fast67chevy2002
Dad's little helper
thanks, I have got several other rear ends with disc brakes, is there any other cars/trucks that can be used with little mods.
Old 08-30-2003, 11:25 PM   #4
kaycee
kaycee's Avatar
Alot o work
Everything is possible
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327/4L60
kaycee is offline   Reply With Quote
Old 08-30-2003, 11:35 PM   #5
chevy_fatman
Where's my beer?
chevy_fatman's Avatar
My '67 has a camaro rear end, is not finished tough and it kind of looks like to be a bit narrow, but I'm gonna use wide wheels, I'll see if I can find a pic of it later.
Paul
How do you make the invisible, visible?.........You take it away.
chevy_fatman is offline   Reply With Quote
Old 08-30-2003, 11:41 PM   #6
chevy_fatman
Where's my beer?
Here's a pic of it not the best, it has the coilovers brackets welded to the axle but it sits too high, have to do something about that
Paul
Old 08-31-2003, 01:31 PM   #7
gmtrucksaddict
any rear that is not 63-72 willrequire some form of weldingtomakework, EXCEPT for leaf spring trucks, those only requireone shockmount relocation, do you have coils or leaves rear under your truck ? if coils then only 63-72will work
also keepinmindthat car 5lug is not same as truck 5lug
gmtrucksaddict is offline   Reply With Quote
Old 09-01-2003, 12:30 PM   #8
fast67chevy2002
Dad's little helper
I have about 5 or 6 5 lug rear ends that have drums brakes. The rear end I have under my frame right now is a 3:73 with drums, is there any car/truck that has a simular mounting for discs or is it easier to buy a kit, to put discs on the rear? Thanks for the info already, but if anyone could add anything that would help a lot.
