400 Small block engine
Ok, I have a 70 C20 with a 350 motor with a brand new turbo 350 trans. Motor is getting old and wore out. I think I want to to a small block 400? Where do you guys think is the best place to get a crate long block? DO I need to change motor mounts from a 350 to a 400? I will thank everyone now, I know there are some experts here.
..................... ____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1970 C20 -_--_--_- ______ _--_--_- /___|__\____ -_--_-_ |_(0)|__|_(0)] 1972 K5 |
Re: 400 Small block engine
External dimensions of all first Gen small blocks are the same. You might have a problem finding a 400 crate motor with an original GM block. 400 ' s are getting hard to find. I suppose I should have asked if you were going small block or big block.
I was thinking small block? Now should i try to find a small block 400 crate motor or just go with a 383 crate motor?
If you really want the 400 it never hurts to look or make a few calls. But don't be surprised if you find one and it uses an aftermarket block. This will be reflected in the price. You could talk to local machine shops and see if they have one laying around that is able to be rebuilt.
I would go with a 383 because the small block 400 doesn't have water jackets between the cylinders. Because of this it tends to run hotter. I have heard that this was the downfall of the sb400.
Posted via Mobile Device |
I would go 454....400 small blocks more prone to overheating than other small blocks. use the 1003 high- performance Fel-Pro head gasket has larger 7/16-inch coolant passages that greater coolant flow to prevent excessive heat buildup between the center cylinders. and use 3 core..
Measure with a yard stick Mark with Chalk Cut with a torch ![]() Built it yourself, don't count on others to to do it for you or with you. It will never get done |
Why do you want a 400 or a 383?
There is a lot that goes into a new engine decision. Bigger is not always better. It could be-just depends on what you want it to do.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
I need a rebuild/new motor. Mine is burning oil and leaking oil. Since i have a brand new trans and a locker in the rear end, I was going to put some horse power to it all.
#10 | |
How much power do you want? A crate 383 can get you 450 HP pretty easy. http://www.jegs.com/p/Chevrolet-Perf...54258/10002/-1 Rebuilding your 350 correctly can get you into the high 300's, and probably less expensive than a 383. All depends on what you want and what you have to spend.
Shawn 1970 Chevy C-10 SWB, 350, TKO 600 5 speed My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881 |
I will probably get flamed, but a basic crate 350 with Tuned Port fuel injection added will give you a lot of oomph (especially low end) and keep the mileage reasonable. That will be way less $$ than a crate 383 or 400. It will allow you to use your existing transmission, exhaust, and accessories.
Lots of good ideas you guys are throwing out. I might have to rethink everything I though?
#13 | |
I decided when I bought my engine that anything over 350 would be plenty for what I'm doing with the truck, which is basically cruising around and playing a little. I wound up with a crate 350 that engine dyno'd 382 HP. http://www.jegs.com/p/Blueprint-Engi...61054/10002/-1 I would have liked to go with a roller cam, but cost was a factor. I've got a little over 5000 miles on it, and pretty happy with it. With the manual trans, open rear and tires I run, its really more than the truck can put to the ground. Wet roads are really difficult....LOL
#14 | |
![]() Join Date: Nov 2001
Although the cubic inch does play a role in the potential performance of an engine. It really is based on the components, pieces and specifics used in the build. It is possible to build a 283ci to walk circles around a 400ci. So, focus more on what you want to achieve. You already have a 350. Find some good heads (your engine may already have good flowing heads, check the casting numbers), then choose a good camshaft (read the description of the cam) and just rebuild what you have. You would be surprised what a flat top piston engine with a good set of heads and a decent cam with do for performance. Although its kinda cool to have "aluminum heads" on your engine, there is no huge advantage to running them. What a head flows is what a head flows. Sure if you can get aluminum heads that flow great for about the same price as steel heads, then definitely get the aluminum heads. Just remember... fuel and air doesn't care what it is flowing through. That being said, you can run a slightly higher compression with aluminum as it is less likely to ping and detonation. But that is all in a whole higher performance level. Also there is a weight savings advantage, but not really worth $500.00 more in a street vehicle if they are costing you that much more. I would go with a 350 or 383 engine before installing a 400. As for small block versus big block. I suggest staying with a small block. Everything is already in place to reinstall a small block. Saves on the wallet.
My Trucks: 1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project 1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver 1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck 1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck 2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White 2002 Chevrolet 1500HD 4x4 Crew Cab 6.0L 4L80E Red |
#15 |
Sorry I just had to do this! :-)
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
#16 |
#17 |
#18 |
That particular smart-a$$ comment was in reference to the aftermarket block. I'm betting they get a pretty penny for those.
Ebay engine is a little too cheap, plus I wouldn't trust it on Ebay. Too many scams on there. I don't care too much if somebody steals $20 on a part I'm buying, but $3k is a big deal. Either find a local engine builder with a good reputation, or buy a crate from a reputable company.
#19 | |
#20 |
I will take that block SS Tim. I will be over on Friday to pick it up ! HaHaHa !!!
#21 |
![]() Join Date: Feb 2009
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
#22 |
A Donovan all aluminum Small Block block. Probably $4500-$5000 new.
They have replaceable iron sleeves for cylinders and only weighs 100lbs. http://www.donovanengineering.com/Bl...ineBlocks.html
My Trucks: 1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project 1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver 1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck 1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck 2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White 2002 Chevrolet 1500HD 4x4 Crew Cab 6.0L 4L80E Red Last edited by 67 cst swb; 04-24-2015 at 12:08 PM. |
#23 | |
#24 |
400 blocks are not that hard to find, but you do have to look listen and search. They were manufactured between 1970 and 79 possibly 80 but have been transplanted into other years. I've pd between $125 bare that will need 2 sleeves and $800 running. I knew a machine shop that had 7 400 blks two years ago.
#25 |
I was thinking about this? What do you guys think?
http://www.ebay.com/itm/281660964041...%3AMEBIDX%3AIT
