Old 04-23-2015, 09:32 AM   #1
KatyPerrysbra
High hump transmission hump?
Is there any differences in the transmission covers from 1960-1966?
KatyPerrysbra is offline   Reply With Quote
Old 04-23-2015, 09:40 AM   #2
1963c-10
1963c-10's Avatar
Re: High hump transmission hump?
There is a high and low version. A bolt in and a weld in version.
1964 Short bed trailer
Old 04-23-2015, 09:47 AM   #3
KatyPerrysbra
So all the high hump transmission covers are the same?
Old 10-05-2015, 11:48 PM   #4
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
other than the differences mentioned above, they will all bolt in 60-66 high hump, chevy, gmc.
so if your truck was a high hump and it is missing, you can source one from any 60-66 high hump truck.
however if you want to put a high hump in a truck that was originally a bolt in low hump, you will have to change the fire wall section as well.
Old 04-23-2015, 10:22 AM   #5
1963c-10
1963c-10's Avatar
Correction low humps can be weld in or bolt in design. With high humps they will be bolt in. Some are for 2wd and some are for 4wd and will have an additional hole for the transfer case shift lever. Some of the large trucks had brake levers in them also.
Low hump, 2wd high, 4wd high - pics taken from various posts and members
Old 10-05-2015, 09:40 PM   #6
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Why do some people still want a high hump even though they have an Automatic Transmission?
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 10-05-2015, 11:27 PM   #7
DLW
Some people need the high hump with aftermarket drop members, engine conversions with larger automatic transmissions (4L80E, 6L80E for example) etc..
DLW is offline   Reply With Quote
Old 10-06-2015, 09:34 AM   #8
LostMy65
LostMy65's Avatar
That makes sense.
I'm going with a Th350 and plan to use the low hump.
But maybe I'll hold on to my high hump just in case I need it in the future.
