04-25-2015, 01:36 PM | #1 |
Front coil springs
Does anyone know a good front coil spring conversion for a racing C10. I tried the drop springs, too stiff, went back to stock V8 spring, still not a lot of weight transfer,and still a bit stiff. I checked Moroso, doesn't make a spring for trucks,does anyone know a spring that will work? Thanks
04-25-2015, 03:21 PM | #2 |
Re: Front coil springs
67 short box with BBC and 350 auto
04-25-2015, 04:12 PM | #3 |
You might try a 6 cylinder replacement MOOG spring. I had bought a pair of Morosos for a 68-72 Chevelle application in the heaviest rate offered. On paper it should have worked. When they showed up they were so unbelievably long that I didn't think I would ever get it compressed enough to safely install them. Other than them taking my head off putting them in I was most afraid they would coil bind with any bump at all.So, No clue if they'd actually work..... Summit and Jegs have a pretty good return policy.
04-25-2015, 04:30 PM | #4 |
meowMEOWmeowMEOW
Its not the spring, its your shock. Find a spring that holds the weight and is the right height, then match a good shock. I've got QA1's up front on a 5" drop (not many companies make an adjustable shock thats only 9" long that will hold a 4k lb truck).
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
04-25-2015, 09:00 PM | #5 |
I have Comp engineering 3 way adjustable, set at 90/10
04-26-2015, 12:55 AM | #6 |
meowMEOWmeowMEOW
And it won't unload the front end at all? Or just not enough.
04-25-2015, 11:21 PM | #7 |
At the body shop.
Super73 used a cherokee spring
" That didnt make it any newer " " Dont antique the equipment " |
04-26-2015, 02:00 AM | #8 |
The sorting I have is way to light for a stock weight truck with big block. Do you itself a favor and go weigh your truck and let us know what the front weight is.
Posted via Mobile Device |
