Quick carpet question
Can someone take a pic of where the front carpet stops? I will be using aftermarket carpet so that may be a factor too. Basically I'm trying to figure out how much painted metal shows between the front and back, if that makes sense? Thanks in advance!
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
Re: Quick carpet question
Any floor board that is still showing after the carpet is down is covered by the carpet strips.
1969 Chevy Custom Camper 3/4 ton Rust free survivor 1972 Chevy Blazer CST 4x4 Almost Rust free survivor 1972 GMC Jimmy 2wd Undergoing surgery |
I thought the "step up" was not covered from the factory. Here is another post on the same type of question
http://67-72chevytrucks.com/vboard/s....php?p=5135965 |
![]() Join Date: Jun 2012
I got Trim Parts carpet for mine and they left enough so you could cover the step up if you wanted. I elected to trim it so it was just on the floor. Not real good pictures of it. I am a little disappointed that there is not a build thread of this blazer of yours.
1972 GMC Jimmy 4x4 LS Swap 1985 Chevy K20 1994 GMC Yukon 2021 GMC 2500HD Duramax AT4 My "It's a Jimmy Thing" Build http://67-72chevytrucks.com/vboard/s...d.php?t=583528 Budget Build 1985 K20 http://67-72chevytrucks.com/vboard/s...d.php?t=801565 |
#5 | |
I'll look into ACC, I'm wanting carpet that is bound at the rear like factory.
#6 | |
Duh. I was thinking the rear carpet
Mine from acc came bound on the back. It only covered the flat area of the floor. Didn't extend upwards at all.
Great looking start. What are your plans for it?
Jeff. '72 Blazer K5 "Camshaft opinions are like belly buttons; everyone has one and no two are alike" My Blazer Build: http://67-72chevytrucks.com/vboard/s...d.php?t=626752 My Engine Build: http://67-72chevytrucks.com/vboard/s...d.php?t=637336 |
That sucks about the SD card. Congrats on finding one with minimal rust that is hard to do. I am sure when you are done with it it will be top notch.
![]() Join Date: Jan 2004
Damn Rick. At least post a finished pic or two ! Mike.
