04-27-2015, 08:00 PM | #1 |
convert old style staggered valve covers
Does anyone have any good ideas on using the old style corvette staggered hole valve covers on the regular heads?
04-27-2015, 08:28 PM | #2 |
Re: convert old style staggered valve covers
Measure with a yard stick Mark with Chalk Cut with a torch Built it yourself, don't count on others to to do it for you or with you. It will never get done |
04-27-2015, 09:09 PM | #3 |
Well, that's not the one I'm lookin for ,but, on his other items he does offer the 55 to 80's plate So Thanks ! I should have said old old style staggered bolt to not so old style even bolt 283 327 heads
04-27-2015, 11:08 PM | #4 |
1961 crewcab
seems like you could make that work... maybe tap the staggered holes into that, and then use counter sunk bolts on the other holes...
I have the same dilemma I have a pair of 56 Canadian sbc "Pontiac" valve covers, that I want to install on my trans am that has a sbc .
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
04-28-2015, 12:56 AM | #5 |
60-66 Nut
Probably 30 years ago I made up my own adapter plates to adapt the staggered bolt Corvette valve covers to the '86 and earlier bolt pattern. I made them out of 1/8" steel but they should have been 3/16" or 1/4" as they tended to seep oil a little. It would be much easier to make a set now with the technology available.
04-28-2015, 01:49 AM | #6 | |
