04-28-2015, 01:20 PM | #1 |
Stock 350 cam suggestions
72 c10, stock original 350, 3.08 posi with a 4 speed saginaw. Dual exhaust with h pipe, stock ram horns. 8.5:1 compression, stock valve springs.
Can anybody tell me why I shouldn't run this cam? SUM-1065 Adv. dur. 280/280 218/218 dur. At .050 .458/.458 110 LSA Seriously, I want to know the disadvantage to this cam, besides the obvious lack of split pattern. Posted via Mobile Device Posted via Mobile Device |
04-28-2015, 09:13 PM | #2 |
mini truck racer
Re: Stock 350 cam suggestions
I cant looks workable to me
1949 5-window 1969 Camaro 1976 Chevy Luv yellow 1978 Chevy Luv Blue 1976 Chevy Luv Black 1979 Firebird Flooded in Harvey 1999 F350 Dually 2005 GMC Sierra 4.8 RCSB 2014 Explorer (wifes) My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148 Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583 |
04-29-2015, 12:01 AM | #3 |
60-66 Nut
You would likely get a better response if you were to post this in the 'Engine and Drivetrain' section instead of the 'Racing and High Performance ' section. You might contact a mod and see if they will move it for you.
04-29-2015, 01:01 AM | #4 | |
I would run screw in rocker studs with a cam like that. You have a manual so that makes it easier.
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=456220 Best 1/4 mile time 12.1 @ 111 w/traction issues 1969 GMC SWB 1964 chevy II Nova ht |
04-29-2015, 12:02 PM | #5 |
Registered Truck Offender
With stock heads and stock exhaust a single pattern cam is not going to be the 'ideal' move. Split pattern cams help bandaid the exhaust flow crippled by incorrectly sized headers, exhaust pipes and mufflers. A stock GM SBC head will 'typically' flow in the 195-200cfm intake and 135-145 cfm exhaust (@ 0.06) just depending on what head your dealing with. The small block head target is to have exhaust flow 80-82% of the intake flow. Even though it gets 'close' at .6 lift, mid lift flow numbers are DRAMATICALLY different and the ratio get's way out of 'ideal' . Add restrictive street exhaust systems and things get worse in a hurry.
I don't know where Surgi has the summit cams ground now. Used to be a place in Mi. (gear dynamics i think was the name) but like most of the house brand stuff, I hear he started buying cams from 3rd world left handed 3¢ an hour labor. But like most things,, we don't make much here any more, and certianally not anything from the bottom end of the price range (quality costs!) Lastly,, flat tappet cams are dated. I don't mean just by lobe design, but the oils available today simply do not support the high pressure contact and wiping effect of the cam and lifter. The internet and real world is FULL of cam failures,, even by guys running premium oils and additives. Every chance they get they remove more and more of the components that keep these motors alive. Environmental issues aside, It's part of the planned obsolesce of the early , inefficient, engines, and to promote new car sales. (not a conspiracy theorist,, this is just fact) Investiment in a roller cam package isn't waranted on a $1500 motor for sure,,, but as things progres and your forced to rebuild,, consider the cost of a retro roller vs the cost of oil changes with special oils and additives. Over the life of the motor it starts to pay for it's self,, not to mention the increased power and efficiency in fuel economy. All that said,, Your looking for reasons to justify using this cam. Sorry,, I can't offer a single one. lol but that's what happens when you ask a grumpy old
Still playin with trucks, even at my age! When you're dead, it's only a problem for the people around you, because you don't know you're dead. .....It's kinda the same when your STUPID. I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral. Last edited by Marv D; 04-29-2015 at 12:19 PM. |
