04-29-2015, 11:28 AM | #1 |
Modified front crossmember
Has anyone modified a factory front crossmember to use tubular arms with the thru bolt rather than the ubolts??
Looking to modify xmember and eliminate weak points |
04-29-2015, 05:56 PM | #2 |
Re: Modified front crossmember
there was a guy that did them years ago. he raised the lower pivot up into the crossmember so nothing hung down below it. you had to cut s lot down the bottom of the crossmember and the new lower a-arm bracket fit up into the slot and bolted to the crossomember using the original lower a-arm u-bolt holes.
I can't remember the guys name, he also do r&p conversions
1967 C10 lwb two tone, 305 & rat fink style floor shifted 700r4, 20" steelies 2004 2500HD utility bed aka Brutus |
