04-30-2015, 11:00 AM | #1 |
good fuel injection system
im looking for a good fuel injection system for my 68 with a 350 bored over to a 355. it has a mild cam in it. i was looking at the edelbrock pro-flow 2 or the proflow xt. is there a better one out there i dont know about?
04-30-2015, 11:32 AM | #2 |
Re: good fuel injection system
If it never needs to rev past 5000 RPM, a factory TPI manifold is great for low end torque. But if you need RPM, either the Pro Flo manifold or the Holley / Weiand Stealth Ram are better up top.
Matt Cramer 1972 Chevy C10 - 4.8 swap, long bed, and maybe one dent free body panel somewhere - SOLD 4.8 LS build thread |
05-02-2015, 02:35 PM | #3 | |
Posted via Mobile Device |
05-03-2015, 10:38 PM | #4 |
FIRST TPI,
It's a great system and sells complete for around $2k. https://www.firstfuelinjection.com
1969 RS/SS Z10 Camaro Pace coupe 1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218 1979 Mazda RX7 1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary 1999 Honda Valkyrie 2006 Corvette Z06 2010 BMW 650i |
05-04-2015, 08:35 AM | #5 |
If you want low end, TPI is where you should go.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
04-30-2015, 07:11 PM | #6 |
fast efi 1.0 or the msd atomic both are better then the other you mentioned
good luck either way bpatrol |
05-02-2015, 10:06 AM | #7 |
Holley stealth ram is a good system.
HSRACER Slammed 53 5 window Blown/Bagged 54 Pickup Patinaed 67 LS stepside Supercharged 67 Nova Bagged 69 Suburban Turbo'ed 5.3 LS |
05-04-2015, 07:27 AM | #8 |
blood type; Retumbo
It's pretty hard to beat simplisity of throttle body injection GM used up to 95. Mix that with some Vortec heads and you've got low end torque on the cheap. Plus it runs on 9-13 psi fuel pressure. That allows you to hang an electric pump on your factory fuel sender
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card |
