05-02-2015, 02:16 AM | #1 |
Dropping An old Oldsmobile 403 into a 1989 chevy blazer?
Could it be done? Its got a 700r4 tranny 4x4
05-02-2015, 07:14 AM | #2 |
Re: Dropping An old Oldsmobile 403 into a 1989 chevy blazer?
Sure, but you'll need an adapter for the bell housing. I don't think there was ever a BOP 700r4 for you to swap tailshafts.
05-02-2015, 10:47 AM | #3 |
05-03-2015, 11:02 AM | #4 |
350 Diesels in the 80's trucks were converted 350 Olds Gas motors.....
05-03-2015, 12:21 PM | #5 |
actually out west here the default swap changing out the 350 diesels was the Olds 403. the 403 shared the same deck height as the diesel so even the exhaust bolted right up
1977 Chevrolet C/10 Silverado. Step-Side, Factory 454, TH400, 3.73 Posi 12 Bolt. 1975 Chevrolet El Camino. 350, TH400, 3.08 Posi 10 Bolt. |
05-03-2015, 08:31 PM | #6 | |
Just here to tinker
That said, the exhaust manifolds and engine mounts will work with the 403. if you can find a 78-81 chevy truck that still has the diesel in it (good luck) everything you need for the swap will be there.
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/showthread.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 73 Chevy C20(Daily)http://67-72chevytrucks.com/vboard/s...d.php?t=852767 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(sold) |
05-03-2015, 10:31 PM | #7 | |
05-03-2015, 10:47 PM | #8 | |
05-04-2015, 10:21 AM | #9 |
Not to argue... but many 350 Deisels just had the heads and intake swapped to gas heads (Requires drilling out head bolts, as deisels had larger bolts) intake and distributor.... Presto, you have a gas burner. thick head gaskets helped knock down compression, gear to drive vacuum pump was same as distributor gear..... Lots of power, solid bottom end and roller cam
05-04-2015, 05:18 PM | #10 |
At the body shop.
A ton of them got swapped in central cal if they hadn't blow up 1st.
A some where resurrected with gas parts after they blew up.
" That didnt make it any newer " " Dont antique the equipment " |
