Old 09-01-2003, 01:35 AM   #1
alta-aj
Wow, what a difference springs make!!
My '72 Jimmy was built with heavy duty suspension. That meant take the same heave duty springs that are used on a long bed half ton and slap them under this poor little Jimmy. It rode like a 5-ton!! Maybe that explains why it only had 70K plus change miles on it when i got it.
Anyway, I put some standard springs under the back of it this weekend and it no longer is trying to break my neck!!
Any body interested in a complete set of heavy duty coils?? (I've got a set of h.d. fronts to throw in with the h.d. rears.)
alta-aj is offline   Reply With Quote
Old 09-02-2003, 09:02 AM   #2
HatGuy
HatGuy's Avatar
Question
How can I Tell what springs I've got?
Joe Peters the HatGuy
72' K5 Highlander
My Daily Driver
http://www.pbhats.com/BLAZER/index.html
HatGuy is offline   Reply With Quote
Old 09-05-2003, 12:31 AM   #3
alta-aj
Here's how:
Standard rear springs are two stage springs in that they have 3 coils in the center that are close together and one on each end that is wider apart than the ones in the middle. I'm guessing that they are made from about 3/4" rod. H.D. springs do not have the two stages to them and are made out of maybe 1" rod (thicker at least).
Old 09-05-2003, 11:06 AM   #4
Davy
Davy's Avatar
Hatguy,
I'm sure you have leafs.
Davy
1970 Blazer CST
Looking for NOS items for my CST restoration.
Davy is offline   Reply With Quote
Old 09-05-2003, 12:47 PM   #5
HatGuy
HatGuy's Avatar
Unhappy DUH!
I just noticed the Jimmy is 2wd.
72' K5 Highlander
My Daily Driver
Old 09-05-2003, 01:17 PM   #6
1970cstblazer
1970cstblazer's Avatar
You can tell if you have heavy front springs if they are the three leaf variety.
1970cstblazer is online now   Reply With Quote
Old 09-05-2003, 06:06 PM   #7
Gee_Emm
ha, I just finished taking the springs off of my 2wd, they look fairly new so I guess a PO put them on and wanted to lift it up. The way the Jimmy sat it was higher then my 3/4 ton. I have some 1/2 spring I am putting in to lower it a bit.
Do you have any pics of that 2wd Jimmy?
Gee_Emm is offline   Reply With Quote
