Old 05-04-2015, 08:47 AM   #1
72 Super
72 Super's Avatar
Modular dies at idle ????
My truck (350 with HEI) will stall randomly sitting at idle at a stop light. It will start right back up. It doesn't do it every time. If the modular is going out would it just stall at idle or would possibly lose power while driving as well?
I've heard the issues of the modular getting it and the engine not starting until it cools off but mine will start right back up.
Thanks,
Ray
72 Cheyenne Super (Purchased new by my parents in August of 71) Black and White
72 Super is offline   Reply With Quote
Old 05-04-2015, 10:04 AM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Modular dies at idle ????
Thanks,
Ray
Does it do it mostly when it is cold or after it is warmed up too? What RPM is your idle set at? Usually the module just dies but I suppose it could have intermittent problems from heat. There is supposed to be a thermal paste between the module and the dist. body.
Here is a picture of a GM module. They are pretty easy to replace.
LockDoc
Leon
Old 05-04-2015, 10:47 AM   #3
72 Super
72 Super's Avatar
Hi Leon, i would say both cold and warm. Once in the driveway but all the other times it was up to temp to or from my way to work.
Thanks,
Ray
Old 05-04-2015, 12:10 PM   #4
LockDoc
LockDoc's Avatar
Thanks,
Ray
If you have a buddy that has an extra HEI laying around I would try the module out of it in yours and see what it does. I also think that auto parts stores can check them for you if you take the module out and take it to the store....
LockDoc
Leon
Old 05-04-2015, 12:13 PM   #5
hugger6933
The module usually either works or it doesn't. In most instances when the module goes out it[the engine] normally doesn't crank again until the module is replaced. Jim
hugger6933 is offline   Reply With Quote
Old 05-05-2015, 12:30 PM   #6
motorcritter
motorcritter's Avatar
I've had HEI modules die slowly- well, over a two period, that's slow compared to instant death. Use the heat sink paste to mount the new one, or suffer the consequence of repeating the ordeal. Dying at idle though, I'd see what my idle speed and carb settings are, first. Fuel pump pressure, too. Something ain't right, and I wouldn't condemn the module too quickly. I've had them tested at LAPS, it can depend on how adept the counter help is at following instruction on the testing machine, though.
motorcritter is offline   Reply With Quote
Old 05-05-2015, 06:46 PM   #7
Mr Handy
Mr Handy's Avatar
When my module died I was driving down the road and boom the truck was off... coasted to the side of the road and was able to get it started again after a minute or two. 100 yards down the road it was done and it was all I could do to get off the road.
Replaced the module for about $12 bucks and used the included goop and all has been good...Tthat reminds me I need to pick one up to throw in the glove box next time I'm at the parts store.
It sounds like to me you have something else going on.
Mr Handy is offline   Reply With Quote
