Old 05-04-2015, 12:55 PM   #1
ranger danger
ranger danger's Avatar
2 Speed Wiper Motor?
My 69' Burb has one speed wipers that start out SLOW and get a little faster after it warms up a bit but will not keep up with even a medium rain. Is it supposed to have 2 speeds? Is there a 2 speed motor and/or switch? Is there a good conversion to an intermittent system with 2 constant speeds? Thanks, RD
1969 C20 Suburban "Rez Dog"
Rebuild America one testicle at a time.
US Army 1977-1979 12B Combat Engineer
US Navy 1979-1983 Gunners Mate Guns (GMG)
NRA Life Member
Unrestrained Children in back seats cause Accidents.
Unrestrained Accidents in back seats cause Children.
ranger danger is offline   Reply With Quote
Old 05-04-2015, 01:41 PM   #2
robb67
robb67's Avatar
Re: 2 Speed Wiper Motor?
My guess is you have a 2 speed motor.
Don't know if this will help but my '68 Panel has a 2 speed wiper motor...I had to replace it recently when it was acting similar to yours. Mine seemed to be slowing down and I even had to reach out and give it a shove to get going in the end. I changed out the wiper motor and it works perfectly now. It was an easy enough job for my panel...most of the work took place under the dash, 3 bolts under the dash and a clip under the outside cowl and it's out. I did have the cowl off out front during my trouble shooting so I lubed up all the moving parts there as well. I hear folks say they can remove and replace the motor with the cowl left on but there is a clip you have to remove and replace which can be done through the louvers (is that what the cowl slots are called?) that would save you messing around with your cowl.
There are 3 different wiper motors (maybe more?)available...mine had 4 terminals but there are also 2 and 3 terminal motors out there. Also, the new motor didn't come with any rubber parts so keep all your original bits if you go for a replacement. You'll want to give in your old motor to avoid the core charge so that's why I mention stripping it of all the rubber bits.
Now intermittent wipers would be nice but I don't know about any conversion...
Good luck!
Rob.
robb67 is offline   Reply With Quote
Old 05-04-2015, 01:47 PM   #3
ranger danger
Thanks, I'll pull mine out and find out if it's a 3 or 4 pin. I did find an intermittent module at LMC for $73.
http://www.lmctruck.com/icatalog/cb/full.aspx?Page=174
NRA Life Member
Old 05-04-2015, 02:26 PM   #4
ranger danger
This is a link to the company who makes and sells the intermittent wiper module. They have some other stuff that's pretty kool as well and they are cheaper!! They are called Revolution Electronics.
http://revolutionelectronics.com/
NRA Life Member
