1983 GMC " Getting Grounded"
So after thinking about what to do for little over 2 years finally started tearing down my 83 GMC. I have had some success in some areas and not so much in others. So here it goes. SO now i am at a stopping point trying to take the bed apart. It is removed and all the bolts have been removed, the wheel tubs, seam sealer, but i can not get it to come apart at the tail gate. I am wondering if there are some pinch welds that i need to drill out any help wouold be appreciated.
Re: 1983 GMC " Getting Grounded"
I am shortening the lower control arms and moving them forward and hopefully this weekend installing cups. I am trying to get as low as possible with 22s without loosing my a/c going ot be close. Pictured below is what I hope the end state to be.
rear crossmember is welded at corners of floor just inside tailgate. If you use cutoff wheel and just cut weld it will come apart. Right where boxside meets floor. Don't know if that clear.
07 Silverado Belltech 4-7 LS2 on stand 66 swb fleet in garage my build thread 76 stepside (painting for buddy)http://67-72chevytrucks.com/vboard/s...d.php?t=645332 |
What kit is that you are using?
#6 | |
Posted via Mobile Device |
Any before and after pics?
Good looking truck and great start!
One thing, your lower control arms might cause some problems with the cups. You don't need to have them hang below the arm. They might get caught up driving low or when you lay out the cup might hit the ground first. You may want to check it out before final assembly.
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
#11 | |
Glad it didnt get caught up. You can flip your nuts and bolts around on that upper plate and get a hair more drop. I had to do the same thing on mine.
Been working on raising the bed floor.
Looks good
#15 |
I like the way you are sectioning the inside. It looks much cleaner but man that is a lot of work!
#16 |
Truck looks good man.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873 The low buck build threads. Check'em out! http://67-72chevytrucks.com/vboard/s...d.php?t=666022 My build thread Crossmembers CC |
#17 |
Finally started making the bed mounts. I didn't want to have to crawl under the truck to remove the bed bolts so now i don't have to with my new bolts.
#18 |
Made my custom transmission cross member. Got it outside to check the body lines after I mounted the bed. I still have to figure out some way to straighten the bent "New Bumper".
#19 |
yeller
That looks like a 73-80 rear bumper....true?
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
#20 |
Diggin The SquareLife
truck looks good!! can u post some pics of the inside of the bed...an that does look like 73-80 bumper....u should get 81-87 bumper
#21 | |
I ended up just cutting the inner bedsides just above where the wheel well met. Ended up at about 7 1/2 inches. I then removes that much from the front and was still able to bolt all the panels togeher like factory. The only problem I had was with the fitment of the tailgate. In the photo from behind you can see the braces that i installed that go from the bed bolts stands to the lower portion of the bedside. It was the only thing i found to be able to hold the bedsides securily enough fo the tailgate to close properly. After finsishing the bed off the truck I leveled the truck frame on blocks then placed the bed on top. With the truck frame level i just leveled the bed and aligned the body lines, then made the bed stands that are pictured previously. I am by no means a professional welder or hot rod builder so I think it came out pretty good. |
#22 |
Inside bed pictures. The last one shows the bottom of the bed runners that I had to trim to get the bed to sit a little lower.
#23 |
Do you have any pics of the truck at ride height and max height? Truck looks damn good
#24 |
The first one is ride height and the second is all the way down. I dont have one of it all the way up.
#25 |
Thanks, I really like the setup.
Tags |
1983 gmc, 1983 gmc sierra, bagged, gmc, tangier orange c10 |
