Old 05-06-2015, 10:39 AM   #1
57chevy3100
1957 Chevy 3100 Pickup
This old gal came with one tail/brake light, any suggestions for an upgrade on the tail/stop lights? I have install the factory cup and switch on the column.
I have tried the small round ones from Bob's, just not bright at all.
57chevy3100 is offline   Reply With Quote
Old 05-06-2015, 09:08 PM   #2
2tractors
2tractors's Avatar
Re: 1957 Chevy 3100 Pickup
I'm thinking round led on mine.
2tractors is offline   Reply With Quote
Old 05-06-2015, 11:37 PM   #3
Richs'55
I'm thinking about something subtle like the Family Truckster would work.
Richs'55 is offline   Reply With Quote
Old 05-09-2015, 10:57 AM   #4
57chevy3100
I am looking for something simple. Not really wanted to do any body work, just drill and mount, LOL
Someone suggested a CJ5 taillight.
Old 06-03-2015, 03:53 PM   #5
Coupeguy2001
Coupeguy2001's Avatar
Turn signals.....
Way back when these trucks were new, you could do hand signals or buy turn signals.
If you installed the turn signal cup, then you know there's another connector hanging out the bottom of the steering column.
The way the factory did this originally, was to install a secondary harness to that connector that went out the cab and stopped right by the voltage regulator.
When they mated the front fender assembly to the truck, they plugged in the prewired fenders' harness.
The difference here is that the trucks without turn signals got a single contact bulb socket on the parking lights, and the turn signal trucks got a 2 contact parking light.
You can't mix the single contact socket with a two pin socket because the bayonets on the bulbs are staggered for the two contact socket and in line with each other on the single contact bulbs.
So you need different parking lights with two contacts for turn signals with staggered bayonet grooves. the same as the tail light sockets.
Coupeguy2001 is offline   Reply With Quote
Old 06-03-2015, 04:27 PM   #6
Wrenchbender Ret
I use the large lights like the big trucks & Jeeps use. You can buy them cheap at the swap meets & they are available everywhere. Like Coupe guy says, you can change the front parking lights to double contact sockets. Wire the turn lights switch to the lights & the wire coming off the stop light switch to the turn switch.
Wrenchbender Ret is offline   Reply With Quote
Old 06-03-2015, 07:58 PM   #7
57chevyman
57chevyman's Avatar
i got these on ebay and they are nice and bright.
Frank
1957 Chevy 3100
2000 Silverado z71 SOLD
2012 Ram 1500 Quad Cab
1992 International 4700
57chevyman is offline   Reply With Quote
Old 06-03-2015, 09:51 PM   #8
Wrenchbender Ret
Here is a photo of my 56.
George
Old 06-04-2015, 03:44 PM   #9
1project2many
Speedway Motors has LED lights and LED Conversions for stock lights.
1project2many is offline   Reply With Quote
