Old 09-01-2003, 01:05 PM   #1
bigjimzlll
bigjimzlll's Avatar
HELP...th350 problem
just got new engine running..the tranny is a forward pattern manual valve body..it is pouring fluid out of the vent..I have a deep aluminum pan and filter extension on it..what could it be???? The dip stick dosent show over full..but its gushing out
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
http://67-72chevytrucks.com/vboard/payments.php
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 09-01-2003, 01:53 PM   #2
Randy70C-10
Randy70C-10's Avatar
The only thing that I can think of (and not sure if this could cause that) but did you by any chance plug the inlet/outlet lines for the cooler?
Randy70C-10 is offline   Reply With Quote
Old 09-01-2003, 02:19 PM   #3
cableguy0
theres too much pressure somehow but it still shouldnt be blowing fluid out the vent. is the tranny cooler hooked up as randy said. i have run a manual valve body and the line pressures are unbelieveably high. did you put it together or did someone else. if someone else did it its time to give em a shout and see what the hell he did
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 09-01-2003, 02:43 PM   #4
MOTHERTRUCKERS
Sounds like a pump passage is plugged in the valve body or 1 of the balls is in a wrong hole in the valve body?
Rest in Peace Ed. Thanks for all the good times.
MOTHERTRUCKERS is offline   Reply With Quote
Old 09-01-2003, 05:19 PM   #5
bigjimzlll
bigjimzlll's Avatar
I think I figured it out...not enuff fluid...added some more(a little too much) and it dosent leak nearly as bad
Anderson,CA
Old 09-01-2003, 06:49 PM   #6
rage'nrat638
rage'nrat638's Avatar
a th400 pump pressure is 210 psi...would think the 350 is some where close to that....
HEY JIMMY.............
rage'nrat638 is offline   Reply With Quote
Old 09-01-2003, 07:17 PM   #7
bigjimzlll
bigjimzlll's Avatar
The dam thing is still leakin......man am I PO'ed..
HEY MARK.....
Anderson,CA
