Drive shaft replacement
Looking for suggestions on replacing/repairing the drive shaft in my '64 c10. Its a 2 piece shaft & the front shaft broke right where it goes into the carrier bearing. Just trying to see what others have done for replacements. I'd like to keep the price low as low as possible on this, but also to want to go too cheap & have it brake again.
It's Better With Nitro
Re: Drive shaft replacement
Is there a local drive shaft specialist in your area? I usually find it easier and cheaper to work with a local drive line shop in my area for these types of things.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
Chevy addict
I have some used two piece shafts in good condition.
Moderator
![]() Join Date: Dec 2012
Did the shaft break, or the yoke?
I agree on staying local, I never had to do driveshaft work before and was shocked at just how inexpensive it was to have them shorten, balance, paint and install new U-joints.
Chevy addict
The shafts I have are longer, you could have one cut down
60-66 Nut
Probably should determine whether you have the light duty driveshaft or the heavy duty driveshaft. The light duty driveshaft will have the carrier bearing hanging from the top of the trailing arm crossmember. The heavy duty driveshaft will have the carrier bearing sitting on a bracket on the bottom of the trailing arm crossmember.
#10 | |
#11 | |
60-66 Nut
The HD carrier bearing is much, much better than the light duty one and the driveshafts are made from larger diameter tubing.
Thanks for looking... I think I'll take what I have now into a driveline shop & see what it will cost to fix mine or get a custom built. Hopefully they won't want an arm & a leg for it. Again thank you for the offer!
