65 no brake lights
i found out today i dont have any brake lights. i looked at the fuses i had a blown fuse. replaced blown fuse and still no brake lights. i do have running lights when lights are on but no brake lights. truck has been rewired by previous owner with a kwik wiring harness
Re: 65 no brake lights
I would check the brake switch. Might not be engaging or might just need replacing.
#3 | |
![]() Join Date: Nov 2013
2) wiring for the brake lights is routed through the turn signal switch. Maybe you have an issue in there? Here's a wiring diagram I found posted in a thread by ACK and a link to another thread with a full wiring diagram. Hope this is helpful.
We'll burn that bridge when we get there My current project: Rust Therapy 62 C10 Numbers 6:24-26 |
#4 | |
Might be lucky and the wires going to the brake light switch are disconnected or the brake switch just needs an adjustment. Start with those two easy things, then you'll have to systematically use a multimeter and check for power starting at the switch and working to the rear at the bulb.
Check to see if you have power to the brake light switch (in and out) if you DO and the turn signals WORK (but the brake lights don't) then you have a problem in the turn switch
Sounds like a ground, the 2 screws that hold the buckets in need cleaned or turned to connect better could be,
64 C10 Fleetside LB 4 Sp/292 Build http://67-72chevytrucks.com/vboard/s...d.php?t=602438 70 GMC 1500 Fleetside LB 3OT/350 Build http://67-72chevytrucks.com/vboard/s...83#post6767983 76 GMC CCLB Dually Build http://67-72chevytrucks.com/vboard/s...d.php?t=691612 79 GMC 3500 Fleetside LB 454/400 90 Suburban Silverado 4x4 350/700R4 97 1500 Cheyenne Short Fleet 350/5sp |
alright i replaced the turn signal switch and i am still having an issue with my rear tail lights and no brake lights. issue with turn signals is it doesn't matter if right turn signal or left turn signal i get both sides in the rear flashing. the front will flash correctly.
got brake lights now.. still messed up turn signals
![]() Join Date: Feb 2014
Are you using stock turn signal switch or and aftermarket one like a Signal Stat 900?
Thanks, Pappyx4!
1962 Chevy C-10 Stepside 383 Stroker, Turbo 400 1966 Chevy C-10 Stepside 250 6Cyl, 3OTT- Daily Driver John 3:16 |
stock... but i have been thinking today if the previous owner didn't have them hooked up correctly? and maybe to an emergency flasher? but i dont see any way to turn emergency flashers on. or could it be a bad flasher? also noticed when following the wires back the grounds are spliced together and 1 single wire go back to the same point in the cab. so would it be possible that because they aren't ran separately that could be causing both to flash?
#12 | |
Posted via Mobile Device |
#13 | |
Senior Car Nut
![]() Join Date: Jan 2008
there is no stock wiring to or from "the negative side of the taillights" so I'm not sure what you have. do you mean the #29 wire is spliced to one of the wires coming from the taillight? if so and this #29 wire is a ground then yes, you do need to disconnect it. as 64chevtruck mentioned, the lights ground through the attachment screws and this is often a problem spot
Larry |
#15 | |
Senior Car Nut
http://67-72chevytrucks.com/vboard/s...69&postcount=1
Larry Last edited by fleetsidelarry; 05-14-2015 at 08:55 AM. |
#16 |
I had that same issue with the turn signals both flashing. I had taken my wire connectors completely apart to clean all the terminals. I had two wires reversed in the double curved connections from the turn signal module on the steering column. The problem was the color was not very good anymore. reversed the wires in the connector and everything works as it should.
