Old 05-11-2015, 05:14 AM   #1
Skunksmash
Skunksmash's Avatar
Inexpensive exhaust system?
Is anyone here aware of a somewhat inexpensive exhaust system that I can buy slowly but surely, over time? For an 87 350 2wd truck. Something that I could install myself, like the ball and socket types. My exhaust is starting to rot off of there, and I could really use a new one.
I've been looking around but they seem to want quite a lot of money just for some hollow tubing. I was hoping someone here might have run across something out there, as you guys seem to come up with all kinds of websites I had no idea existed.
Skunksmash is offline   Reply With Quote
Old 05-11-2015, 08:04 AM   #2
andrewmp6
Re: Inexpensive exhaust system?
Try some local exhaust shops.
Old 05-11-2015, 08:32 AM   #3
71swb4x4
71swb4x4's Avatar
Here the local shops are cheaper than mail order. You can't order the parts for the price they charge out the door.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 05-14-2015, 10:39 AM   #4
piecesparts
Parts and more parts
piecesparts's Avatar
Agree with this one.
Frank
Old 05-14-2015, 09:39 PM   #5
Skunksmash
Skunksmash's Avatar
Originally Posted by MikeB View Post
A CAT reduces NOx, probably not fumes you can smell. If fumes are bad, your carb may be too rich.
In Texas, for vehicles that are over 25 year old, you can get Antique Vehicle plates that require no inspections at all. The fee is only $50-something every 5 years.
Its fuel injected. The old TBI stuff
And I don't have much of an inspection, its $11 and no sniffer test. I was just referring to the fumes for my own sake, sometimes if I need to let the truck idle or run for a bit, like at my house, the fumes get pretty bad.
Old 05-11-2015, 08:40 AM   #6
cadillac_al
I always buy the dyno max kits for around $120-150. Summit and Jegs sell the same kits I believe.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 05-11-2015, 09:33 AM   #7
MikeB
MikeB's Avatar
For stock replacement pipes, use the Walker catalog below to find only the ones you need. Walker lists the 87 2WD pickup as R10/R1500, nomenclature that was used by Chevy and GM from 87 to 91. http://www.walkerexhaust.com/catalog...catalog-lookup Start by clicking on "Light Duty Truck" in the middle of the screen.
Here's another source: http://www.lmctruck.com/icatalog/cc/...hTerms=exhaust
Here's an inexpensive kit if you have dual exhausts and headers:
http://www.summitracing.com/parts/wlk-89007
As mentioned above, a local muffler shop might be cheaper depending on the work you need, but they will use "crush" bends, whereas the pipes above are mandrel bent and less restrictive.
Mike
1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- sold
1981 C10 Silverado LWB -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 05-11-2015, 01:30 PM   #8
1979-square-body
1979-square-body's Avatar
I've seen a few trucks with the pieces from Auto Zone used. Seems to work as well as anything else, you can get parts as you can afford and go bit by bit.
1979-square-body is offline   Reply With Quote
Old 05-12-2015, 05:04 AM   #9
andrewmp6
I would have a exhaust shop fix all that is wrong with your exhaust now,Then save up and buy whatever exhaust kit you want in the end.
Old 05-12-2015, 10:02 AM   #10
blazer2007
I usually just get the shop to make the part I need,go on a slow day and usually just a cheap cash deal.The rest of the exhaust i just bought some u-bends or 90,s or whatever I need and make my own,plus you,d be surprized on the stuff they throw away from mistakes,I,ve gone dumpster diving and found lots of good stuff for repairs or whatever
blazer2007 is offline   Reply With Quote
Old 05-12-2015, 10:12 AM   #11
MikeB
MikeB's Avatar
Originally Posted by blazer2007 View Post
plus you'd be surprized on the stuff they throw away from mistakes, I've gone dumpster diving and found lots of good stuff for repairs or whatever
I've done that a few times behind a local muffler shop. Picked up some perfectly good take-off pipe sections, as well as some lengths of straight pipe.
However, they recently put up a fence around the back! Guess they must be selling it by the pound as scrap, or maybe they occasionally use some pieces themselves.
Mike
Old 05-12-2015, 10:56 PM   #12
Skunksmash
Skunksmash's Avatar
lol!
Well thanks for the recommendations all. I'll take a look at each recommendation individually, then go with the cheapest! heh
Anyway, I may as well move on to my next related question. I have the old dinosaur giant catalytic converter still on there. Would it benefit me in any way, to buy a high flow mini cat? And would just any old mini cat do? Is there any real difference between them besides inlet and outlet size?
I know I want a cat because the fumes are bad now, as it is. Don't really want to make it a lot worse by not having a cat.
Old 05-13-2015, 05:51 AM   #13
S10Fan
Old Heap Driver
I installed a Summit brand system for a friend a couple years ago, square body long bed, duals, nice quality stuff that had a good sound.
_____________________________
Bryan
'99 Silverado 1500, 4.3, 5-speed, reg cab, short bed
'50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser.
'40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver.
S10Fan is offline   Reply With Quote
Old 05-13-2015, 08:29 PM   #14
MikeB
MikeB's Avatar
Mike
Old 05-13-2015, 09:14 PM   #15
Hiluxxulih
Hiluxxulih's Avatar
I bought my exhaust system from the cat back at at auto zone and it fit pretty good , it was a stock type system .
1985 Chevrolet Custom Deluxe
4x2 , 305 v8 , 700R4 transmission
Hiluxxulih is offline   Reply With Quote
