Old 09-01-2003, 09:17 PM   #1
sider68
sider68's Avatar
Oil Usage
I have an 81 GMC 250 inline 6 using oil.There are no leaks but air filter is full of oil.What is the problem?Engine has about 80,000 miles on it.
sider68 is offline   Reply With Quote
Old 09-01-2003, 09:43 PM   #2
TROYLV
oil in air filter
i would pull the valve cover and make sure the oil return holes were clean.
troy wilson
TROYLV is offline   Reply With Quote
Old 09-01-2003, 09:46 PM   #3
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Check your PVC valve. You also have a leak only in the higher RPM range. Have some throttle the engine and check around the oil pressure sending unit and filter.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 09-02-2003, 01:32 AM   #4
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
Doesnt that also mean that there is a chance of excess oil get in the breather do to blowby?
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
Old 09-02-2003, 07:47 AM   #5
Mike76251
I like that engine but it seems to always suffer from one problem......the cylinder closest to the firewall wears fastest and causes piston rock and blowby.
Mike76251 is offline   Reply With Quote
Old 09-02-2003, 10:39 PM   #6
sider68
sider68's Avatar
I put in a new PVC and took it off and hear it still rattles.I assume therefore it is working.The other hose is a crankcase ventilation and it seems O K.What next?
Old 09-03-2003, 04:58 PM   #7
82 Silverado 4X
Genuine Chevrolet
82 Silverado 4X's Avatar
If it isn't leaking oil then it must be burning it.
If the PVC is good then it's time you start looking again.
Does it smoke a bit when you first start it?
This could mean valve seals.
Does it smoke even the slightest bit when you are driving around?
This could mean bad rings.
George
82 Silverado LWB 4x4 350 SM465 NP208
77 Chevrolet Blazer Chalet 400 TH350 NP203
82 Silverado 4X is offline   Reply With Quote
Old 09-03-2003, 10:57 PM   #8
sider68
sider68's Avatar
It doesn,t smoke.There is oil in the air breather and i,ve replaced air filter twice.
Old 09-04-2003, 12:37 AM   #9
crackajacka
Stylin
crackajacka's Avatar
does it puff puff like this when u take the oil cap off while its running?
Ive been traveling for some time, with my fishin pole and my bottle of shyne.
Most Girls like finished products and just dont understand what a good addiction does for you
http://www.paulwall.us/
crackajacka is offline   Reply With Quote
Old 09-04-2003, 12:38 AM   #10
crackajacka
Stylin
sry forgot pic
Old 09-04-2003, 02:44 PM   #11
sider68
sider68's Avatar
What causes that?
Old 09-04-2003, 10:51 PM   #12
crackajacka
Stylin
worn piston rings or in my case the piston made a groove in the cylinder wall and all the compression was leaking into the crankcase.. have u looked at the valve springs? might get lucky and ones stuck open or something like that but if its that bad its rebuild time. another thing is hows the oil pressure? is it pegged out? if it is its compression getting to the crankcase
