Second Chance Program
1977 Silverado Crew Cab.
This tread will be a build thread of sorts. Mostly a documentaitino of the tinkerings.
Last week i traded my 78 K25 for this 77 C20 crew cab. Short term plans are to do a full round of "new used vehicle maintainacne" Stuff like full tune up, new fluids, etc. The truck has sat for nearly 10 years before i got it so it needs a good going over before it's really road worthy. Long term plans are to convert it to 4x4, get it painted, and probably end up with a 6.0 or 8.1. Here are some pics. My old K25, [IMG] http://i597.photobucket.com/albums/tt55/y5mgisi/Mobile%20Uploads/20141111_122630_zpsau32jmvm.jpg[/IMG] The Crew Cab. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Stay Tuned! Should be a fun project!
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt. 77 C20 crew cab Silverado. 396/th400. In work. |
Re: 1977 Silverado Crew Cab.
love a 77!!!!!
These are the colors i want to paint it.
Nice truck to start with. Are you going to eliminate one of the cab lights and go back to 5 or eliminate all of them?
1987 GMC R2500 SC 454 T400 1988 Chevy R30 CC DRW 12 valve Cummins NV4500 GearVendors |
I'll probably just replace the burnt out bulb in the one and leave them how they are.
Thanks!
Nice grab! Seems to be the same original colors as my 75. Also you pretty much have the same plans as i do for a 4x4 and 6.0 or 8.1 swap. I will be subscribing.
![]() Join Date: Jul 2014
Sweet truck! Subscribed!
Well call me crazy but the original colors are growing on me. This is what I think it would look like all painted up.
Well so far i have done the following,
Got it registered/insured/legal. Front calipers. adjusted the rockers. Hooked up the choke. Fixed the seat belts. Changed the door dome light switches. Adjusted the power steering belt. And pressure washed it to death. Today i started a new project. I got the truck with 6" speakers cut into the kick panels. I had these new 6x9s I was going to put in the 78. So after some measuring I decided it looked like these could fit in the kick panels. And they do! Before, ![]() After, ![]() And plenty of room for the e brake, ![]() It did take some doing. And if the magnets were any bigger they would require a spacer. But in the end, they do fit! And sound decent enough for the old 80's deck thats in it now!
can you tell me how long the truck is with the cab? I got an 8 ft bed and it still seems giant lol
1986 Chevy Fleetside Wrangler (Canadian Only) ![]() |
Its somewhere between 20'-21'. Its a biggn!
Picked up a set of rear doors last night. Perfect condition but dirty for $25 for the pair and they were already off the truck! Friends in high places! The driver side one is the only one that really needs replaced. The passenger side one I just got so I could have matching factory tinted glass.
Indeed.
Pinsco63 (Scott) took the canopy off my hands today. I think it looks much better without it! Looks like a pickup now! ![]() ![]() ![]()
#15 |
#16 |
based on my experience with the 6.0 in a 3/4t pickup, you might as well just go for the 8.1 and have all the power you could need!
1999 GMC Suburban K2500 SLT, 454/4L80E 1991 Z/28, 6.0L/T56 1949 GMC 250, S10 Frame, 6.0L/4L80E Instagram @aceshighspeedshop |
#17 |
They seem like they both will cost within a few hundred of each other and get within a couple mpg of each other, so why not get the big block? At least that's my current thinking. However, there is a 07 6.0 for $400 in a town where I am going in a couple weeks. I think I should stop by and check that out. If I can get it and it looks like a good deal, I'll probably pick it up.
#18 | |
#19 |
Ephesians 2:8
Love it! going to make a great truck for you
72 Suburban making it mine My 79 C10 story 79 C10 LS swap 94 LS swapped Daily Driver Tahoe Limited Instagram - @piersonclassics 83 K20 Farm Truck Build |
#20 |
So I have been talking to the wife and a plan is confirmed. After the 4th, 90% of extra money and time is going to getting the crew painted before Halloween! I think I can do it. Not having ever painted a truck before, It might be tough, but there really isn't much body work to be done. I'm thinking about putting a lean to off the side of the garage and having that be my paint area. It's about a 15'x25' space which would be better than trying to paint it in my garage. That's still slightly up in the air, but is likely to happen. Either way, the crew shall be lookin good before long!
The space, ![]()
#21 |
How much did the disk brake setup run you? Ive been thinking of doing the same...
#22 |
The brackets are something like $100 from diy4x.com and rotors are like $25 each, calipers are $20 each, pads are $20, hoses were $20 each etc. Probably about $300 all said and done?
#23 |
Bumper to bumper it does not look much longer than the newer truck next to it.
I like the stock color combo. People say Chevy did not make 4x4 crew cabs before 1979 and they were only 1 tons. I have personally seen 2 pre 1979 3/4 ton 4x4 crew cabs. Both were studio transportation vehicles and both had small blocks in them. I think your 4x4 conversion is a great idea. Those old trucks with white steel wheels and 11.00x16 mud and snow tires look really cool. |
#24 |
Agreed on all fronts. Tho I do believe that these crew cabs only came 4x4 in one tons and I believe they began offering them in 77.
#25 |
I have a '76 K20 Crew; D44. 350, th350, np203. All from the factory.
I may have a problem.. 1976 K20 Crew, 1978 K30 Crew, 1981 K30 Crew, 1985 C30 Crew, 1987 C30 Dually Crew, 1988 R3500 Crew, 1990 R2500 Crew, 1991 V3500 Crew, 1991 V3500 Dually Crew. |
