![]() Join Date: Apr 2010
50 3100 5 window with Vette suspension
This is a truck I'm building for my buddy Ernie. I apologize, I h 've early photos as well. I'll post them later. This build is using complete C4 suspension, stock vette front cross member, stock 50 chassis, 84 Vette motor with 92 Vette TPI, 700R trans, and 18" Camaro wheels. Here's some pics.
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 |
Re: 50 3100 5 window with Vette suspension
Here's some more shots of the frame work. It was boxed the entire length from front crossmember to rear suspension mounts. The front frame rails were notched and the C4 crossmember integrated into the existing chassis.
Here's some detail on the rear suspension. The stock lower control arms were pitched in favor of custom made adjustable lowers with 3/4" Heim joints. Much easier than cam bolts that way!
![]() Join Date: Aug 2012
Sounds like a really cool build! Should handle like its on rails when done.
Here's what we used for a gas tank. 69 Mustang 20 gallon. Framing was built out of 11ga. 1.25" square tube. Sway bar was relocated above the frame to circumvent clearance issues in the rear.
Work continues
I would move that sway bar to beneath the frame were it belongs, your going to run in to rubbing on the frame. I have my tank in the back also and made room for sway bar.
LIL ERV the 50-3600 396 BBC stroked to 415 cid Richmond 6spd over drive C4 rear Porter built a arms Never give the Devil a ride,because he'll want to Drive! |
Here's some shots as the driveline was getting set up for initial startup. The lower intake was modified to fit the pre-86 heads.
Ernie decided to go ahead and run a mild cam, so an Energizer 242/242 (at .050) with matched lifters was selected. Stainless headers, gunned alum. Valve covers, and a double roller timing set finish it out. Serpentine setup is donated from a 92 Camaro.
In the pic the sway bar is loose, so it looks a lot closer to the frame than it will be when it's finished.
![]() Join Date: Jul 2012
Nice, neat work. Everything looks good. Ernie must be happy!
![]() Join Date: Mar 2011
Hey Chris, all I can say is you sure keep busy. Nice job on the chassis, etc....Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
Nice! Looks like you have your motor mounts welded to the frame and your not using the stock mounts on the vette K member. How did you determine engine placement?
1952 Canadian Chevy 1300 C4 IFS & D44 IRS 5.3 HO L33 My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=632938 ![]() |
Thanks guys. Motor placement was done the same way I do my s10 swaps. Set the cab on, position the driveline so the distributor has about 1" or so of fired clearance, then fab mounts.
#15 |
![]() Join Date: May 2007
you have just a great job haha
#16 |
I do love my job!
#17 |
Sorry that it has been so long since I've updated this thread. This one was safely at home when my shop burned down. Disregard the 1st 2 pics they are a mistake. pic 3 is the chassis ready to go home.pic 4 is the cab being worked on. And pic 5 is the AC vents in the dash.
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 Last edited by skymangs; 12-04-2016 at 03:26 PM. |
#18 |
up next, is the firewall. Got to clean it up some. The last one is a very happy Ernie next to his finished chassis. The 2nd to last one is my idea to dress up the firewall a little bit.
#19 |
What I did was to use an old 283 valve cover. I just cut out the script portion of it and weld it (very carefully) to the firewall.
#20 |
Here is some additional pics of the firewall, and it's finished appearance.
#21 |
Chris, the truck is looking really good. I like the Chevrolet script too.
Like Jim said, it is great to see you posting again! |
#22 |
It is good to be finally posting again, definitely better than the alternative. Apparently I actually died a couple of times in the hospital. Definitely glad to be here today. A whole lot of time to think about one's priorities in life. I think I'll actually be stronger because of this.
#23 |
We never know what God has planned for us, he decided there was something you still needed to do...Jim
#24 |
Formerly- 1972SuperCheyenne
![]() Join Date: Oct 2008
^^Totally agree, so glad youre ok man. Any chance you have more closer pics of how
C4 cradle was integrated into stock chassis, debated doing this a couple times.
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
#25 |
As you can see, I just cut the top and bottom of the frame. As I lowered the frame it spread the frame rails just a little bit. Just in the area that I wanted to weld the crossmember in. It was really quite simple.
