Old 05-16-2015, 12:11 AM   #1
FamilyBowTie
Those running 20"s - any issues w/ Steering
I have a good line on some 20" wheels and tires, and was wondering are there any issues with steering?
49 5 window on s10
http://67-72chevytrucks.com/vboard/s...d.php?t=671706
FamilyBowTie is offline   Reply With Quote
Old 05-16-2015, 02:00 AM   #2
dubds10
Stalker Nate
Re: Those running 20"s - any issues w/ Steering
Depends on what suspension you have & the offset of the rims. There's lots of room up front with our 20s.
1957 GMC SWB stepper modified summer time driver
1963 Chevy Fire Dept. Command Center Van 2 ton - future food vending truck project
1965 Chevy P10 Ice Cream Truck project
Instagram - TheDonutDiner
FaceBook - @UscreamIscream
dubds10 is offline   Reply With Quote
Old 05-16-2015, 12:29 PM   #3
FamilyBowTie
On a 49 - Going to run an s10 chassis up front and an s10 4x4 in the back.
I looked into Camaro (2010) and they have 6/6.5in backspacing and 35-40mm offset. I actually have some 15" IROC on the truck and they rub on the front (no spacers).
49 5 window on s10
Old 05-16-2015, 02:19 PM   #4
Dustint
Depends how low you are going, and how wide the front wheel/tire will be.
As a general rule of thumb the s10 chassis will like a wheel that is closer to a 0 to +5 mm offset range. It is also something you should note that the new camaro bolt pattern and the s10 pattern are not an exact match.
Dustint is offline   Reply With Quote
Old 05-16-2015, 04:28 PM   #5
FamilyBowTie
I know the new camaros are 120mm and are not a true 5x4.75, I am looking for other options as well.
Looking to go with a static 2/3 for now but would eventually like to bag it and lay frame.
49 5 window on s10
Old 05-17-2015, 10:55 AM   #6
Dustint
I'm running 20x8.5 with 245/45/r20 tires, with 4.75'' backspace. Can't quite turn lock to lock without contacting the frame, but it is very close. that's about the most backspace you can run with that tire size. Anything more and you would probably want to run spacers, I'm pretty against that, and it also limits you on the outer edge with fender clearance.
Old 05-17-2015, 11:14 PM   #7
Sim6
Sim6's Avatar
I think Ceil has that set up.
http://67-72chevytrucks.com/vboard/s...d.php?t=642010
1969 Chevy C10 SWB 350/400 4"-6" drop on steelies
53' Chevy 3100 5 window http://67-72chevytrucks.com/vboard/s...d.php?t=660793
http://67-72chevytrucks.com/vboard/s...d.php?t=771679
Sim6 is offline   Reply With Quote
Old 05-21-2015, 01:20 PM   #8
oossuuu754
oossuuu754's Avatar
Originally Posted by Sim6 View Post
Here is what I am running on Cecil
The fronts are ridler 695 18x8, 5x4.75 +0 4.5"
Tires are Kuhmo Ecsta 255/55/18
I do have the issue with front tires rubbing on a sharp turn, you can make a 90turn without rubbing but a 180 you will need to back up.
---Shawn
Cecil-1953 5 window build thread
Skymangs..Chris of Old Sarge customs had a shop fire and was severly injured. To help with the medical bills and expenses a fund has been set up here....http://gofundme.com/c49h5mjx8 More details are here...http://67-72chevytrucks.com/vboard/s...=1#post7253189
oossuuu754 is offline   Reply With Quote
