05-18-2015, 04:52 PM | #1 |
Temporary Floor Sealing
Any ideas for temporarily fixing rust holes in the floor boards? I'm going to slap some POR15 on but won't be able to get to welding in new pieces until next year. I was thinking about drilling holes and putting in some rubber stoppers...
Any one have ideas? I would leave it alone but up here in the NW we'll be getting rain from Sept-May and I've already found it wet under the carpet since I got it a week ago just from driving.
1965 C10 Longbed Stepside 1969 Chevelle Malibu 1962 C20 Fleetside - Build Thread (Sold before I could finish) |
05-18-2015, 06:14 PM | #2 |
Re: Temporary Floor Sealing
maybe just some sheetmetal and caulking and screws for now
05-18-2015, 06:46 PM | #3 |
Chevy addict
Screws and sheet metal. don't put the POR on until you are completely finished, it's almost impossible to get off once it's dried.
05-18-2015, 07:11 PM | #4 |
Or use the por15 with their fiberglass matting that you paint right over the with Por15... I've used it on very minor rust holes before and it's hard as steel once dried. I wouldn't use over quarter sized holes or bigger though..just an idea. If the holes are small and minor this could be a near permanent fix.
05-18-2015, 11:10 PM | #5 | |
05-18-2015, 11:23 PM | #6 |
could you explain that por 15 and fiberglass matt routine again with a little more detail?
Projects: 65' Chevy C10 swb (rebuilt chassis) 65' Chevy Panel swb 64' Chevy C30 flatbed "above" 80' C30 "beneath") Parts: 66' GMC 2503 & 65' GMC I1500 |
05-19-2015, 08:54 AM | #7 |
You don't need to use POR-specific fiberglass mat, any of the chopped-strand type fiberglass mat will work.
Do all your rust grinding & surface prep, then trim a piece of the mat to cover the holes and overlap onto good metal. Lay down a coat of POR on both sides of the metal as usual, then lay the mat on a plastic covered surface and brush it with POR on both sides, forcing the POR into the weave. Lay this over the still-wet POR on the metal, and use a POR covered brush to force any air bubbles out and the mat hard against the metal. Wait for the POR to dry and put another coat of POR on both sides to seal the mat & metal together. Be aware that you are going to have to cut out the entire POR & mat section and weld in new metal as there is no way to remove this fix from the metal for welding.
1964 C/10 Longbed Fleetside, base model. (build thread) (pictures) SOLD 1964 C/10 Shortbed Fleetside, Deluxe. (pictures) SOLD |
05-19-2015, 10:16 AM | #8 |
I used regular fiberglass matting on my floors by the kick panels on my k20. Then sprayed some sound deadening undercoating over it before layig my carpet it. Worked great
05-19-2015, 06:48 PM | #9 |
Thanks everyone. I think I'm going to use some POR15 on the stuff I'll be cutting out anyway and then probably the caulking/sheetmetal. A little worried I might overdue it if I go the fiberglass route
05-19-2015, 07:55 PM | #10 |
But Found Her 25yrs Later!
This almost sounds like a good permanent fix for the floor. I mean, if you clean the floors and you only have small holes why couldn't it last you the rest of your life?
05-20-2015, 03:20 AM | #11 |
All depends. How bad the rust is to start with, where you live (climate), & how the truck/car will be used once done. I did this to an old survivor Plymouth Valiant I had, I didn't drive it or park it in the rain once I got and I gave the pin hole floorboards this treatment and it lasted for many years, put new carpet in it earlier this year to sell it and floors and trunk looked like I had just done them. I also did this to the pinhole trunk floor in my 68 Charger RT show car about back in 2001. I haven't lifted the carpet in it since...might have to go investigate to see what it looks like now...probably looks like it was just done, It hasn't been in the rain or washed (just wiped down) since.
