Old 05-18-2015, 06:32 PM   #1
michael bustamante
michael bustamante's Avatar
removing spray on liner
so i picked up a great 67 passenger fender. only one problem. it has a medium coat of rattle can spray on liner on the inside . Grrrrrrrr
so any of you guys know of a quick way to get all this crud off?
1967custom
michael bustamante is offline   Reply With Quote
Old 05-18-2015, 06:43 PM   #2
enaberif
Re: removing spray on liner
Grinder + wire wheel cup.
enaberif is offline   Reply With Quote
Old 05-18-2015, 06:56 PM   #3
Fitz
If you don't mind repainting, trot down to your local Home Depot and pick up a quart of this stuff. Just like Superman in a can:
Fitz is offline   Reply With Quote
Old 05-18-2015, 06:58 PM   #4
michael bustamante
on my way fitz. thank you. its primered so no paint to damage.
a wire whell would just take way too long with all the little crevices on the back of these fenders.
thanks!!
1967custom
Old 05-18-2015, 07:20 PM   #5
hugger6933
Michael, Make double barrel sure that you get all I mean ALL of the stripper off or else it will seep into the new finish and also leak from the seams onto the new finish. Jim
hugger6933 is offline   Reply With Quote
Old 05-18-2015, 07:46 PM   #6
briank
Try easy off oven cleaner, ive heard that works.
briank is offline   Reply With Quote
Old 05-18-2015, 08:01 PM   #7
kell490
scraper and a propane torch is what I have used on undercoating just soften it up with hte heat then use the scraper to scrape it off. Then you can hit it with what ever stripper you want or get it blasted.
kell490 is offline   Reply With Quote
