rear suspension question
in the interest of full disclosure the rear of my truck is lowered with the brackets that specialtyretail sells here..... now, on to the question. Since lowering it I had to cut off the bump stop bracket because I was sitting right on it. Now I have a few inches of suspension travel. When I press the accelerator something in the rear is shifting. The truck goes to the right and then when I let off it settles back straight.
I've been under it and everything is tight... u-bolts, leaf spring bolts (leafs have new bushings), probably needs new u-joints soon. Could it be motor mounts? I don't think that would cause the shifting in the read end though. |
Re: rear suspension question
Any ideas?
Sounds like loose rear axle to me, but you checked everything....
Did you use new u-bolts? Is the flip kit actually well seated in the old leaf perch?
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
yeller
I am not a fan of those flip brackets, I strongly suggest looking at the Bell-tech or Western Chassis flip brackets. Compare the design, you will see the difference. I also agree, something is loose...check everything back there carefully.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
x2.
If you used the original u-bolt plate, it doesn't have a relief hole in it for the leaf spring center bolt. Make sure you slightly off set the u-bolt plate so it isnt sitting on the leaf spring center bolt or you wont be able to get the rear end fully tightened. Another way to fix this is to drill an off set hole in the u-bolt pląte to match the off set in the flip bracket.
John 82 Chevy Silverado 350ci/TH350 ![]() |
Thanks for the suggestions guys. I'm moving into my new house this weekend so maybe I'll get to tear it all apart next weekend.
