05-19-2015, 12:31 PM | #1 |
Custom grind camshaft for nearly stock 350
looking to get the most out of my 350 and cant find anything off the shelf that im excited about so Im goin custom grind.
72 c10, 2wd original 350 with less than a 100k on it. 3:08 posi with a 4 on floor, open air element, warmed over qjet and a dual exhaust. Compression should be right around 8.5:1. Im keeping stock ramhorn manifolds and stock valve springs. Redline is 5000. 295/50/15 on the back for a 26ish inch tall tire. Looking at .450 inches int/exh with a split duration favoring the exhaust on 108 lsa. My question is, whats the max exhaust duration recommended at .050 inch of lift for my setup? 215-218? Dont care about advertised duration. My intake will be 8-10* less duration than exhaust. Truck maybe taken to the track a few times a year for fun, otherwise its just my low and hopefully quicker, cruisin C10. Real world experience with a cam close to these specs would be appreciated. Basically i want an Isky 264 megacam with a split duration and just cant seem to find anything. Posted via Mobile Device |
05-19-2015, 12:37 PM | #2 |
Re: Custom grind camshaft for nearly stock 350
The cam I really like in a 350 is a Crower 00223 with a 1800-2000 stall convertor and a 3.50 to 3.73 rearend gear.
http://www.crower.com/catalogsearch/...XVBWo1&q=00223
My Trucks: 1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project 1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver 1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck 1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck 2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White |
05-19-2015, 01:20 PM | #3 |
Thanks for the suggestion. Did you use this cam with stock valve springs and mostly stock motor except for what you have listed?
05-19-2015, 02:38 PM | #4 | |
remember... the better the "combination" you have, the better things will be. An awesome cam won't be so awesome if the motor is a worn out 8.2:1 with worn out rings, horrible flowing heads, a worn out timing chain and an out of tune carb. Cams aren't magic.
05-19-2015, 01:54 PM | #5 |
If you want a good all around cam mellings puts out what they call a torque cam
part # mtc1 or if can find a 350 horse 327 cam that would be good for your application |
05-19-2015, 04:41 PM | #6 |
By "stock valve springs" I hope you do not mean originals. They do wear out and you will not get the most out of a new cam with weak springs.
05-19-2015, 07:25 PM | #7 | |
05-19-2015, 08:31 PM | #8 |
The comp dual energy cam may be a place to look. They have a pretty big split lift duration with more focus on the exhaust I ran one in a S-10 [I use to build a lot of V-8 S trucks.] and enjoyed it a bunch it was the bigger of the two grinds they make. Thew smaller one of the two sounds like it is right up there alley. Call 1-800-CAM-HELP and ask them what they think would be best with what you have. I am with the above poster out of all the cam designers and makers you still have not found a cam? Call the Comp cam help and they will hook you up I think the Dual energy or the Extreme energy cam may be a good fit. Jim
05-19-2015, 08:38 PM | #9 | |
05-19-2015, 08:41 PM | #10 |
Im just gonna have to start calling I guess, Ive put in many cam request forms with 3 companies over the last month and none have replied
05-19-2015, 09:11 PM | #11 |
Ok so comps Xe256h specs are right on the money but I want it on a 108 for some more peak torque and little more chop at idle as a bonus. I understand this will close my powerband up a bit to something 1200-4800. Im not real crazy about hearing the wear and tear on valvetrain that XE's allegedly have but the cam specs seem too mild for it to be a huge concern.i dont see any links on comps page for a custom grind request, think they could make that happen?
05-19-2015, 09:27 PM | #12 |
Sounds to me like you are looking for a narrow power band at lower rpm's. A tight LSA will do that. A similar effect can be achieved by advancing the cam timing as well so bear that in mind when looking at specs.
05-19-2015, 09:35 PM | #13 | |
05-19-2015, 09:52 PM | #14 | |
For the 108LSA, you will likely need the custom grind. The XE256H is too much cam, IMO. The dyno test here is on an engine with 9.25CR. http://www.compcams.com/v002/Pages/386/XE256H-10.aspx If I get time, I'll do a dyno simulation for you. I'm going to say up front without headers, you will be dis-appointed. |
05-19-2015, 10:05 PM | #15 |
Honestly i cant make much more than 300hp or ill be grenading the saginaw so I figured Id try to go for some nice peaky torque after Ive already rolled into gear. Trying to make as close to 300hp as possible with as much torque as possible is my goal. Why will i be disappointed without headers? With the favored exhaust duration and a nice mandrel bent 2.5 inch h piped dual exhaust, i didnt think id be having any reversion issues but maybe im wrong.
Posted via Mobile Device Last edited by Cgoldhill; 05-19-2015 at 10:20 PM. |
05-19-2015, 10:27 PM | #16 | |
05-19-2015, 10:34 PM | #17 |
05-20-2015, 02:15 AM | #18 | |
Now I'M gonna ruffle some feathers and NO DOUBT get a lot of dis-agreements, and we all know that's a waste of time LOL I'm not changing my opinion. I think the RAM'S HORNS are some of the WORST designed exhaust manifolds EVER. The exits on the 3,4,5, and 6 exhaust ports are HORRIBLE. You have the exhaust coming out at a 90 degree angle hitting a WALL and pulses going not just downward but UPWARD smack dab into the #1,2,7, and 8 exhaust ports causing loads of reversion into the other 4 ports. ANY header with 4 individual pipes exiting parallel to each other will FAR outperform the Ram's Horns due to less reversion and actual scavenging effect. Block huggers, Corvette tubular (86' for instance), shorty's, long tube and the best the long tube tri-y's. |
05-20-2015, 09:32 AM | #19 | |
05-20-2015, 10:05 AM | #20 | |
With this info in mind mechanicalman, do you still think the xe256 is too big? ill be satisfied as long as the cam gives me a performance bump for now, and even more later on with more mods. i want a cam that will squeeze the most power out of the heads as the heads may never be changed. All the complimentary breathing bolt ons will be added on in due time. Gasoline, id still like to know why you think the 108 lsa will suck? Im seeiously asking to make sure I havent missed something. i realize ill lose some powerband and top end power but i dont need to make max hp, and id rather have 350flbs and 250hp than 320ftlbs and 260hp, just as an example. Posted via Mobile Device |
05-19-2015, 10:23 PM | #21 | ||
"I ain't nobody, dork."
108 LSA will suck for what you want. Put the LSA up around 112 to 114 and you will still have a rumpity idle and way better vacuum and a wider power curve.
Just searching online isn't really exhausting your resources. All the cam manufacturers can make any cam you want on a custom grind. What you want has already been thunk of by someone else... trust me. So Comp or Lunati or whoever probably already have a grind for it. Some one mentioned the good ol' "350 hp 327 cam". I've used this grind for many builds. It's just a dang good cam grind. Specs are: GM part number: 3863151, Lifter type: Hyd., Duration @ .050: 221/221, Lift: .447/.447 LSA: 114 Engine: 327 (350HP) L79 Gary
05-19-2015, 10:50 PM | #22 | |
Im waiting for ten other people to now post how old and archaic that grind is and how a modern lobe design will run circles around it. I know i can get a custom cam, thats what this post is all about because i cant seem to find anything that fits my criteria. i mean no disrespect to anyone and am not trying to ruffle feathera but Im getting alittle frustrated with everyone reading 3 sentences of two posts and replying with an answer that is completely unhelpful to my question as it doesnt match up with anything Ive been asking. Mechanicalman is the only one who actualy answered my question and then offered some actual usable incite pertaining to my motor, not someone elses hypothetical. I apologize if this sounds forward but this has become an incredibely annoying trend over all forums Ive been on recently. Posted via Mobile Device |
05-19-2015, 11:39 PM | #23 | ||
No disrespect taken. But if you really want to get a custom grind... it's just a phone call away. You have in your mind what you want. No opinion is going to change it. So you will need to talk to the cam companies via phone or email and order what you want.
I honestly would like to see what you come up with from ordering a custom cam. Gary
