Old 05-20-2015, 12:00 AM   #1
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Door weather strips for 71 Chevy - Success stories
Stayed on, great fit, door closes correctly.
I've looked and really, the most convincing success stories I've seen are one guy who took them off a Honda, and another who spent the entire day gluing the seals on (not sure part mentioned). Anyone have a success story they'd like to share? What parts did you use?
Incidentally, I've bought a ton of NOS, and only two were returned. They were the "LH" and "RH" weatherstrips "3951813-4". Quotes have "special" meaning.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 05-20-2015, 02:46 AM   #2
BruthaMan
US Army Veteran
BruthaMan's Avatar
Re: Door weather strips for 71 Chevy - Success stories
Mid to late 90s Dodge Dakota or the smaller trucks. I've read about these many times here. Last year, while on a visit to family, I took some time out to go to a good parts yard that I knew still had some old 67-72s.
Picked a few wiper motors, the ventured over to the dodge area and picked out a good set of door seals. They fit my truck great. I had purchased the famous precision "clip on" from a vendor here, but there was a physics issue in getting those door shut! No amount of adjustment would even get the doors close to shutting with the new ones.
BruthaMan is offline   Reply With Quote
Old 05-20-2015, 09:37 AM   #3
BrianG
BrianG's Avatar
I bought the Precision clip on style. Bummer to hear that they didn't work for you. I have not installed mine yet, but now you have me nervous that I'll have issues getting my doors to close.
BrianG is offline   Reply With Quote
Old 05-20-2015, 09:53 AM   #4
67 chevelle
67 chevelle's Avatar
This is what I used on recommendation from this board
I ordered a brand new set from Hondapartscheap.com
P/N 72315-SVA-A01ZA for the right side.
P/N 72355-SVA-A01ZA for the left side.
works great ,, they are allitle big for the space but the bottom plate at the rocker smooths out where it wants to bunch up , hardest part is getting all the old glue and strip off ,, truck has much less road noise now ,, and they clip on and off easyly for painting and body work
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs
67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive
58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white
69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive
67 chevelle is offline   Reply With Quote
Old 05-21-2015, 01:03 AM   #5
71CHEVYSHORTBED402
Clip on instead of glue huh?......Sounds good. Thanks for the recommendation.
Tony
Old 05-20-2015, 11:13 AM   #6
Willie Makeit
Willie Makeit's Avatar
used dodge dakota. $5 at my local pick and pull. a bit of castrol super clean and some hot water and they look brand new. fit like they were made for these trucks.
Willie Makeit is online now   Reply With Quote
Old 05-21-2015, 01:04 AM   #7
71CHEVYSHORTBED402
Huh........Dodge and Honda.
Tony
Old 05-20-2015, 11:27 AM   #8
leddzepp
Moderator
leddzepp's Avatar
86-96 Dodge Dakota. Plentiful at the junkyards, cheap, fit like a glove, clip on-no glue. Win win win all the way.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 05-20-2015, 12:14 PM   #9
WarMonger
WarMonger's Avatar
out in Ventura CA, no good part yards. Do you happen to have a part number for the Dodge ones so I can get them new?
..................... ____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1970 C20
-_--_--_- ______
_--_--_- /___|__\____
-_--_-_ |_(0)|__|_(0)]
1972 K5
WarMonger is offline   Reply With Quote
Old 05-21-2015, 01:05 AM   #10
71CHEVYSHORTBED402
Thanks. I'm thinking 86-96 Dodge Dakota.
Tony
Old 05-20-2015, 12:26 PM   #11
michael bustamante
michael bustamante's Avatar
i used a set from a 88-98 chevy full size and these worked well and since they were used they were soft and no door closing issues at all. they were a little long but i cut off about a foot from the bottom and the door seal covers the cut well
1967custom
michael bustamante is offline   Reply With Quote
Old 05-21-2015, 01:09 AM   #12
jocko
jocko's Avatar
I used GMC Paul's clip on (avoid glue!!) VERY high quality, but take forever, I mean forever, to break in/compress. I adjusted the hinges and latches outward to try to compensate without being unsightly, and they STILL are too full to shut the door with the good old solid clunk, have to slam. It's been somewhere between a year and a half and two years. SO, next time for me - will be Dakota wx strips.
Old 05-21-2015, 11:28 AM   #13
67 chevelle
The honda door weatherstrips require a stout pull ,, not a slamm , they seem to be the perfect thickness
Old 05-21-2015, 03:14 PM   #14
nzc10
nzc10's Avatar
I brought a cheap set off year one and just glued them on iv had no problems with shutting the doors
"I ain't got no time for side tracks!"
69 R/T Charger
72 C10 Chevrolet
85 302 Jaguar
99 955 Daytona
10 1050 Speed Triple
nzc10 is offline   Reply With Quote
Old 05-21-2015, 04:31 PM   #15
markmdz
anyone have a pic of the stock seals compared to the dak seals on their truck? I'm very interested and will be doing this very soon.
markmdz is offline   Reply With Quote
Old 05-21-2015, 04:41 PM   #16
WarMonger
WarMonger's Avatar
I would like to see what the clips look like on the dodge seal. Anyone have a pic of that?
1970 C20
-_--_--_- ______
1972 K5
Old 05-22-2015, 07:56 AM   #17
Willie Makeit
there are no clips. the weatherstip has a "slit" that pushes over the pinch weld of the door opening.
Old 05-22-2015, 10:02 AM   #18
WarMonger
WarMonger's Avatar
So what are they talking about when they say the dodge one has clips?
1970 C20
-_--_--_- ______
1972 K5
Old 05-22-2015, 11:12 AM   #19
FirstOwner69
FirstOwner69's Avatar
Not the best pictures, but these are the Dakota weather strips installed. As Jocko described, the "clips" are enclosed within the rubber.
FirstOwner69 is offline   Reply With Quote
Old 05-22-2015, 10:49 AM   #20
jocko
jocko's Avatar
It just means that there is metal embedded in the rubber that "clamps" onto the raised crimp seam. No way to actually see them without tearing the seal apart. It really is the best way to go and allows the seals to be re-usable. They're sturdy and don't fall off though.
Old 05-22-2015, 11:13 AM   #21
WarMonger
WarMonger's Avatar
I'm with you now. It all just came together.
1970 C20
-_--_--_- ______
1972 K5
Old 05-23-2015, 08:55 PM   #22
71CHEVYSHORTBED402
Unless I'm mistaken, the Dakota door seals aren't molded like the GM parts for the upper inside corner, correct?
If I'm on the right track, the correct years (Dakota) are 87-96.
Tony
Old 05-23-2015, 10:30 PM   #23
leddzepp
Moderator
leddzepp's Avatar
They are not molded but they conform just fine.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 05-23-2015, 10:48 PM   #24
FirstOwner69
Correct. But, as leddzepp said they fit fine. Here are a couple pictures of mine. Inside and outside.
Old 05-24-2015, 11:30 AM   #25
JPsChevy
JPsChevy's Avatar
Are you guys using new dakota seals or pulling seals off junk trucks and reusing?
Opportunity is missed by most because it is dressed in overalls and looks like work.
- Thomas Edison
JPsChevy is offline   Reply With Quote
