Old 05-20-2015, 03:05 PM   #1
blown240
blown240's Avatar
X Frame Exhaust Questions
I need to redo exhaust. My plans are block huggers into 2.5" tubing, run outside the frame rails, thru a cherry bomb and then thru a dynomax turbo muffler. Then I will either exit in front of the wheels, or out the back. I had a similar setup on my 51 Chevy car and I loved the quiet but nice sound I got.
My question is the best way to get to the outside of the frame from the block huggers. Can I go thru the space between the torsion rods and the frame? Right now my exhaust hangs really low, and I need to get tucked up nicely.
Here are some pics of what I have now:
You can see how low the exhaust is:
This is where I want to run the exhaust thru:
And then I was thinking of having it go thru this are where the body mount ends:
and then stay nice and tucked in this are on the outside of the frame. I will probably need to wrap something around those wires to protect them from the heat...
These are the block huggers I am starting with:
and I plan to reuse the mufflers that are on there now since they are less than a year old:
Any suggestion are appreciated.
'61 Panel - Helms Bakery Truck - Daily Driver - FOR SALE
blown240 is offline   Reply With Quote
Old 05-20-2015, 03:35 PM   #2
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Re: X Frame Exhaust Questions
Here's a thread I've been watching :
http://67-72chevytrucks.com/vboard/s...d.php?t=657228
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 05-20-2015, 03:53 PM   #3
blown240
blown240's Avatar
Thats an interesting thread. The only problem that I see is that where they have the X, my trans crossmember blocks. My truck has a 700r4 and I really don't want to have to make a new mount.
Old 05-20-2015, 04:31 PM   #4
vin63
It's Better With Nitro
vin63's Avatar
While my truck is a '63, here is how I routed my exhaust to the outside of the frame with my shorty headers. You should be able to snake the down tube from the collector between the torsion bar and the frame at the frame rise.
…after coating and paint:
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 05-20-2015, 04:38 PM   #5
blown240
blown240's Avatar
Thanks for the pics! Any pics of it as it goes back to the rear? Pics are always inspirational.
Old 05-20-2015, 04:47 PM   #6
vin63
vin63's Avatar
…the turnouts off of the mufflers are just in front of the rear tires:
Old 05-20-2015, 04:48 PM   #7
blown240
blown240's Avatar
Thanks! Thats exactly what I am thinking in my head. The only difference is that I will have a cherry bomb between where you have your clamps.
