Old 05-24-2015, 12:02 PM   #1
gramps77
swapping to Vortec heads WITH smog
For you guys more familiar with the workings of an engine, am I gonna shoot myself in the foot if I swap from old boat anchor 76cc crate engine heads to Vortec 64cc heads?
I buddy had mentioned the efficiency may cause some of my readings to go up. It passes CA smog easily now. I did the swap in a 66 Nova I had (no smog) and the car ran a lot better and gained noticeable power is my reason for wanting to swap
gramps77 is offline   Reply With Quote
Old 05-24-2015, 01:08 PM   #2
MikeB
MikeB's Avatar
Re: swapping to Vortec heads WITH smog
Efficiency is a good thing when it comes to emissions, unless you live in Bizarro World like this guy.
If everything but heads and intake manifold stays the same, I'd bet the Vortecs will have cleaner exhaust.
Mike
1969 C10 LWB -- owned for 36 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- sold
1981 C10 Silverado LWB -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 05-24-2015, 03:16 PM   #3
mattcrp1
mattcrp1's Avatar
NOx may go up due to the higher compression.
My Chevy habit is paid for by Ford diesels...
Here is my SLOW LS install: http://67-72chevytrucks.com/vboard/s...55#post6456355
Caliper Rebuild: http://67-72chevytrucks.com/vboard/s...d.php?t=613748
Upper Control Arm Bushings: http://67-72chevytrucks.com/vboard/s...d.php?t=616974
IG mattcrp1
mattcrp1 is offline   Reply With Quote
Old 05-24-2015, 05:28 PM   #4
gramps77
And thats exactly what was mentioned.
Any one have some real world experience?
Old 05-24-2015, 07:46 PM   #5
bmchevy1979
bmchevy1979's Avatar
Also I don't think there is a smog legal intake for vortec heads with a carb
<Brandon>
1974 Chevrolet K5 Blazer 350sbc/SM465/NP205, dana44 front, corp 14bolt rear with 4.10s and a powertrax locker, custom rear bumper 400sbc in the works.
1981 GMC C1500 stepside 250i6, 3spd, 12bolt with 3.08s 2.5/4drop on 15x10 with 275/50r15
81 GMC C3500 cab-chassis dually with utility bed 350sbc, Sm465, 14bolt with 4.10s nv4500 getting ready to go in
1979 Chevrolet K5 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434096
1976 Chevrolet C10 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434195
bmchevy1979 is offline   Reply With Quote
Old 05-24-2015, 08:42 PM   #6
gramps77
well dang it, thats not good.....although they looked up the Edelbrock I have on there now and showed me some CA smog code that said what I had was ok. (they initially thought it wasnt but the wording made it ok)
Old 05-26-2015, 06:22 PM   #7
MikeB
MikeB's Avatar
I've read that your statement is true for some combustion chamber types, most notably hemispheric chambers, which is why the new Hemis really aren't Hemis at all.
However, I seriously doubt if GM would have designed and implemented Vortec heads AND increased compression if the result was increased NOx vs. the old heads with D-shaped chambers.
Depending on the piston style used in the OP's old engine, as well as actual deck height (typically around 9.030"), compression with 64cc chambers may increase to only 9.0:1, which is less than 96-up Vortec 350s at 9.4:1.
On another note, doesn't California offer any kind of exemptions for older vehicles?
Mike
Old 05-27-2015, 04:11 PM   #8
mattcrp1
mattcrp1's Avatar
If it were only 4-6cc I would more inclined to go with your train of thought, but the OP stated 76cc original heads going to 64cc heads. 12cc is quite a jump.
When I had my smog license here in the bay area I performed combustion chamber cleanings to remove carbon from trucks to get the NOx readings in spec.
I think this calls for a before and after test
I think it is also a function of the old pellet style cat converters verses the newer honey comb style and there efficiency.
IG mattcrp1
Old 05-26-2015, 07:57 PM   #9
Ziegelsteinfaust
I know on the tbi's they get the egr from the exhaust manifolds. So a possibility is there.
The real problem may lay in making it look stock enough to fool the people.
Having built, and been a part of several smog "legal" builds I would just use standard performance heads.
Ziegelsteinfaust is offline   Reply With Quote
Old 05-27-2015, 09:54 AM   #10
MikeB
MikeB's Avatar
So they actually look at the engine on a 30+ year old truck to make sure all the parts are factory stock? Just how in the heck do all the engine and car builders in CA sell anything to in-state customers? What's next, jail time for installing aftermarket parts?
It's so sad that politicians run amok have taken over such a beautiful state and the home of hot-rodding.
Mike
Old 05-27-2015, 08:07 PM   #11
beamn7
Gramps, if it was me and knowing how our smog laws are, I wouldn't bother. Drive it and enjoy it and keep your fingers crossed that someday the law will change and allow for rolling model year exemptions....
A smog legal fit you could do is a set of World Products sportsman 2 heads and a performer manifold. That would wake it up a bit and be legal.
http://www.theengineshop.com/product...ron-heads.html
On the other hand, you could do an entire late model motor swap and then take it to a referee to get it signed off on but then you have to meet emissions level for the engine model year you install and not the vehicle model year...
Mike, yes, in CA we have to smog any vehicle newer than 1975 and it gets a visual inspection as well as a tailpipe sniff. You would think it would be 30 years or older but no, they base it off when cats first got installed on vehicles...
Oh well, I'm going to go an pretend to water my yard now...
beamn7 is offline   Reply With Quote
Old 05-28-2015, 09:26 AM   #12
gramps77
keep in mind, a CATALYTIC CONVERTER IS NOT REQUIRED for me. Its a Heavy Half Ton and makes the cut off by 50 pounds according to the door sticker Matt. Just about everytime I smog it, the guy will go back and forth to "the book" and GVWR sticker verifying its not.
The engine is the 260 hp crate 350 which is "rated" at 8.5-1 compression but Ive read its actually closer to 8.1-1.
Old 05-28-2015, 11:01 PM   #13
'68 Newtricks
'68 Newtricks's Avatar
Are these actual Vortec heads or just TBI heads? I'm running '92 heads on my 400 with a ProProducts intake manifold and EGR. Passes visual and sniff My comp is ~9.2:1
'68 C10 SWB
'85 K30 Blazer
'68 Newtricks is offline   Reply With Quote
Old 05-29-2015, 11:49 AM   #14
gramps77
actual Vortec, 062/906 heads are what Im looking at.
Old 05-29-2015, 10:26 PM   #15
'68 Newtricks
The aluminum heads I believe have a carb conversion manifold but no provisions for EGR. I'd love to see one in person as it might be possible to drill a couple holes, tap, and install a dummy EGR. As long as it's there, that's all that maters. It doesn't even have to work
'68 C10 SWB
'85 K30 Blazer
Old 05-31-2015, 04:56 PM   #16
Tom
driving is in my blood
Tom's Avatar
Even if the emissions do go up slightly with the better heads and compression, your not running a cat yet so you can always add one to bring the readings back down. I put a vortec 350 into my old 79 and ran cats just so I wouldn't have to even worry about emissions or emissions tuning before taking the test.
