05-25-2015, 02:22 AM | #1 |
BBC Headers
I feel like I've spent days looking for headers for my 65. I had to scrap the twin turbo ls idea [read my build to find out why] so I decided to put a big block in it instead...the idea of trimming my frame doesn't make me happy since I just painted the engine compartment today. A lot of the old threads have links that aren't active anymore and seemed to trail off rather than give a real answer. The motor is a 396/402 now 408 which will rev up to 6500 or so, I know a truck needs power down low, But 90% of my driving time is on the freeway and just a couple miles off I90 to work so building it for down low isn't for me. It will have a 4L80E so I can cruise and I plan to have a cable operated shifter from B&M so there wont be any linkage in the way.
Am I better off just asking the manufacturers which will fit my truck?
Custom Painter/Restoration Specialist 1965 GMC 3/4 Ton LB SOLD? 1964 Chevy El Camino in full restoration 1991 Chevy S10 288K+ miles 2nd Owner SOLD 2020 RAM 1500 Warlock |
05-25-2015, 10:10 AM | #2 |
Re: BBC Headers
I went with sanderson the fit was great, I did have to do some trimming on the frame. I have pictures on my build thread (framers big block)
05-25-2015, 11:29 PM | #3 |
60-66 Nut
Re: BBC Headers
I believe any off the shelf header will require trimming the top flange of the frame. The '67 and earlier trucks were not available from the factory with a big block, so the frame needs to be trimmed. I used '73-'87 truck headers on mine, but then my Suburban isn't very low. Some guys have used Chevelle headers with success. They don't hang down as low as truck headers. But those will not work with the original bellhousing crossmember in place.
05-26-2015, 09:42 AM | #4 |
Re: BBC Headers
I used Hedman Elite HTC 69136 2" primary tubes on my big block which list as 68-87 truck headers. Did have to trim the upper frame flange, fit great around the POL mounts. Few pics on how they look/fit.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer Last edited by 1963c-10; 05-26-2015 at 09:49 AM. |
05-26-2015, 11:03 AM | #5 |
Re: BBC Headers
They are a tight fit. I had to trim about an 1/8" off the right side. The right header cleared the stock mount but the left didn't so I went with the tubular mounts which worked. These are the Hedman Elite headers. I would to with some chevelle headers as these hang down real low.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
05-29-2015, 12:46 AM | #6 |
Re: BBC Headers
I'm going to use the Sanderson ones and I'll just fab a new trans crossmember. My boss has pretty much the same ones on his 57 GMC, they have a narrow profile which is good for tight frame fitment.
