![]() Join Date: Feb 2015
Steering column question from a new member.
Is the '67 column a one year only? The lower spline shaft is HUGE compared to the replacement I sourced from a '69. I bought the truck with a custom vice grip steering wheel that ruined the steering wheel side of the shaft. The columns look very similar, just the lower shaft diameter is different. Should I go back and get the lower shaft? Or should I try to source a '67?
I searched, and could not come up with an answer. Thanks in advance. |
#2 | |
The Older Generation
Re: Steering column question from a new member.
'67 & '68 standard columns are the same and '69-'72 are basically the same. The only differences are auto/manual/tilt features.... LockDoc
Welcome, to use the column you have to replace with you need the intermediate shaft. It will fix all of your troubles. Jim
#4 | |
Thank you, I'll head back and grab the rest. Any idea if there is an advantage in grabbing the '69 power steering gear, or is my '67 good enough? |
#5 | |
LockDoc
Good to know, it is definitely a power steering gear. I'll continue with the column swap, Thanks so much.
