Old 05-28-2015, 08:28 PM   #1
Feldsine
Feldsine's Avatar
Fresh Start After 15 Years
Going to start a freshly rebuilt 350. I bought this truck (71 C20) from the original owner, and he had put about 10 miles on the engine before parking it for 15 years. I pulled the dipstick, the oil was so clean I could barely see it. I'm going to change it anyway before starting, as well as the radiator water.
Questions are:
1. I would like to prime the engine oil. I read elsewhere that I would get an oil priming rod and spin it with a drill, however, this might or might not get oil through all the passageways, lifters rockers and cam. Is there some detail that I need to pay attention to when getting the rod?
2. I'm planning to change the oil and radiator water before starting. I'm not really wanting to get into the tranny. Is it ok to run the tranny enough to get it to an oil change shop to change it, or is that critical enough to change before starting? I don't have a good place to work and it would make a mess.
3. I bought a can of "SeaFoam Spray". It was suggested that I spray this into the spark plug holes to lube it up, and crank the engine by hand a dozen times or so before starting. That sound good?
4. Got most of the gas drained. Figured I would add about 5 gallons, and just before starting, and after oil priming, with the plugs still out, I would crank the engine till good gas started coming out the end of the line. Then hook it up and go for it. There is a filter inline by the tank, I figure I'll be changing that a few times pretty quickly.
Stan Feldsine - Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=673856
1969 C10 LWB Fleetside - 350 - 700R4
1971 C20 LWB Fleetside - 350 - TB350
Feldsine is offline   Reply With Quote
Old 05-28-2015, 09:35 PM   #2
RustyBucket
RustyBucket's Avatar
Re: Fresh Start After 15 Years
Jeg's sells a priming tool for $20, I've made several out of old distributors. It should pump up oil pressure spinning the pump with your drill. You'll probably have to rebuild/replace the carburetor. If you're REAL lucky the transmission will just take off and work for you. Put some truck pictures on please.
Dad always said, "Son, WISH IN ONE HAND, and ......."
Current toy trucks:
'71 GMC 1500 SUPER CUSTOM short/step, orig. dk. blue, 350/700r, ps,pb, A/C
'72 Blazer 2wd, ochre & white, 454, tremecTKO 500 5spd. ps, pb, A/C, tilt
Last 10yrs of hobby vehicles, had a FEW more in the 50yrs. before these:
'66 Plymouth Belvedere City of Miami cop car clone.
'70 Nova 406"sb, 13.5-1, solid roller, Brodix, p.glide/t.brake, back halved, 9" Ford, spool 4.88, cage,ladder bar/coilover, 10.5 tire....... SOLD!!
'67 C10 short/step side mount spare -- SOLD!!
'72 Jimmy 2wd, 350/350, ps, pb, fun driver, lots of bondo & a shiny red paint job..... SOLD!!
'69 Nova 350, 4spd, A/C, ps, p.b, ...SOLD!!
RustyBucket is offline   Reply With Quote
Old 05-29-2015, 01:09 AM   #3
Got Smoke?
Got Smoke?'s Avatar
Most auto zone parts house's have loan a tool program, mine has a oil priming tool they rent. Pay a deposit, use the tool, take it back get you're deposit back. Works great for things you don't need to use very often.
97 Dodge 2500 12V NV4500... way to much to list.
79 Chevy K20 4" RC/37" GY OZ's 350/465/205.... restoration somewhere in the futue....
NEW: Project 88 Chevy R3500 3+3 / 88 V3500 3+3 combing two to make one....
Got Smoke? is offline   Reply With Quote
Old 05-29-2015, 01:22 AM   #4
leftybass209
leftybass209's Avatar
You can pull a valve cover when you prime the engine. That will allow you to see oil start to flow through your cylinder heads.
leftybass209 is offline   Reply With Quote
Old 05-29-2015, 01:48 AM   #5
In The Ten Ring
I have this same thing coming up in about a month. So I can rent an oil priming tool? NICE. How does this tool work?
In The Ten Ring is offline   Reply With Quote
Old 05-29-2015, 02:25 AM   #6
leftybass209
It mimics the shaft of the distributor, with a drive end that fits into the slot on the pump, and an end that works with the chuck of a drill. Connect the drill (semi-powerful or it'll burn up) and run it! It's that easy. You can Google search a picture of it.
Old 05-29-2015, 07:22 AM   #7
Chevy Fan Always
Chevy Fan Always's Avatar
I have an old distributor that works great. I ground the top of the shaft to accommodate a drill motor.
Chevy Fan Always is offline   Reply With Quote
Old 05-29-2015, 11:48 AM   #8
Davidf
I made a priming tool out of a screwdriver. Just cut the handle off an old screwdriver and chuck in a drill motor. Done.
Davidf is offline   Reply With Quote
Old 05-29-2015, 08:35 PM   #9
Feldsine
Feldsine's Avatar
Thanks guys. I'll look into renting the rod from Auto Zone, thanks for that suggestion. I'll get some Marvel Mystery Oil. Fortunately, the engine moved relatively easily with the breaker bar. I didn't move it much, just an inch or so, but at least it wasn't frozen up. The plugs were all rust free too.
This thing has those auxiliary tanks on it, so it has hoses running all over the place. Going to be a challenge, but they will all be replaced.
I pulled the hose off the bottom of the tank, and nothing came out, I'm hoping that means there is nothing in it and not that it is plugged up. I stuck a rod down in the tank and it seemed like the last inch or so came up wet.
I'm tempted to start stripping down my C10 to get parts for this one. The C10 has a new gas tank and new Edlebrock Carb with linkage set up for the 700R4. But I'd like to keep both of them running, and probably sell the C10 after I swap the tranny.
That's going to be a pain, cause I had the shaft cut down for the 700R4, so I'll need a another stock shaft for TB350 going back in it, and the one in the C20 cut down for the 700R4. Oh well.
I'll get some pics up sometime. This thing is covered with surface rust, but there are no dents. The only cancer is between the drip edge and windshield. A friends says he can help me patch that up and prime and paint the truck.
I'm torn, this thing is "school bus yellow". Will it grow on me? I'm considering changing the color. But maybe after the rust is gone the color will look better.
