05-28-2015, 10:12 PM | #1 |
Windshield stainless .. Could it be better? I hope so.
I'm not really satisfied with my new stainless.. There are gaps that I don't think should be there.. Is this as good as it gets or am I being too picky?
05-28-2015, 10:13 PM | #2 |
Re: Windshield stainless .. Could it be better? I hope so.
Closer pic
05-28-2015, 10:14 PM | #3 |
Side view
05-28-2015, 10:16 PM | #4 |
It seems to me that oem does in fact fit tighter.
05-28-2015, 10:26 PM | #5 |
looks a lot like mine after I got it redone with OEM trim from 67-70 and precision gasket. The prior install used a non-precision gasket and 71-72 after market trim. It looked good from the outside and the trim laid flat but it leaked like hell when I drove it in the rain.
05-28-2015, 10:31 PM | #6 |
Look at the upper corners on the inside. Are they seated nicely and look correct?? My windshield rubber corners looked somewhat like yours and i had to go back after a new windshield was put in and pull on the corners to get them to lay flat against the body on the outside. Good luck Brian F.
05-28-2015, 11:12 PM | #7 |
That's about what mine look like, aftermarket trim and gasket. Irritatesthe crap outta me. Leaks when wet too
United States Marine Corps 2000-2011 Iraq and Afghanistan veteran Just living life now and enjoying it and my wife, daughter and son |
05-29-2015, 12:15 AM | #8 |
I would hope the fit of pieces, even aftermarket, would be better than that. The gap is terrible..must be a better solution?
"You can take the man out of PA, but you can't take PA out of the man" |
05-29-2015, 05:55 AM | #9 |
I carefully hit on it both the trim and gasket with a rubber mallet to get a better fit
carefully is the byword here
05-29-2015, 09:43 AM | #10 |
Judging by the photo I would think that it's not seated all the way down. You can see a faint line on the vertical trim that looks like it should come down another half inch or so. Then she should lay flat. Looks like a nice build! Good luck!
05-29-2015, 12:32 PM | #11 |
Thanks pdawg.. It's been a long one and I'm trying to make it as nice as possible.. It's my first..
05-29-2015, 02:42 PM | #12 |
The first one's always special !
Posted via Mobile Device |
