05-29-2015, 12:10 PM | #1 |
Engine sitting for 10 years: should it be oil primed first?
I commented on this other thread, where his engine sat for 15 years. My dad (original truck owner) is dead set against me priming my engine to lubricate before starting.
He reasons that "all the oil drips down overnight anyway" and that it will "take 15 minutes for my truck to start anyway, priming isn't necessary." Also he feels that getting into the distributor will screw up the timing and I'll never get it started then. What say you guys? |
05-29-2015, 12:31 PM | #2 |
Re: Engine sitting for 10 years: should it be oil primed first?
You should prime it.
However - one of the ways you could do that is to pull the spark plugs and spin it (with the distributor in place) before starting it. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
05-29-2015, 12:34 PM | #3 |
10/30/19
If it were my engine I'd change the oil,all the filters,new spark plugs and wires. Pull the distributor and prime the engine.
Fight the good fight, finish the race, keep the faith |
05-29-2015, 12:37 PM | #4 |
The purpose of priming is to get oil to the bearings BEFORE the engine is spun. So, it matters not if the engine starts or not, the damage can be done.
05-29-2015, 12:49 PM | #5 |
Understand not wanting to disturb the dist. but priming is really a must.
I like to drop the pan on an engine that has been sitting for that long for a general inspection. Pulling the plugs, lubing the cylinders and slowly turning it by hand is a small start. Changing the oil and filter is a must and spinning the oil pump through the dist hole is the best way but it can also be done with a pressuruzed pre-luber if you can get access to one. It works by injecting oil into the galleries through a plug like the oil sender hole. Still not as good as sucking clean new oil up though the engine driven pump though.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
05-29-2015, 01:23 PM | #6 |
Six in a row makes it go...
I'd pull the plugs and squirt some Mystery Oil in the chambers to get something on those nice, dry rings. Then I'd do what Keith above said. Some cheap, fresh oil might be good, with an oil change shortly afterward.
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086 66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790 CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224 “The height of sophistication is simplicity." - Clare Boothe Luce |
05-29-2015, 02:50 PM | #7 |
Sitting over night is LONG way from sitting 10 years. If it were me I'd spray some light oil in the spark plug holes, spin the engine by hand a few times, replace the oil and filters, then prime it with the tool at the distributor.
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed. |
05-29-2015, 03:14 PM | #8 |
I started a nice all original Cheyenne super without priming it. ran good for a minute then screwed the motor up.. DONT DO IT
05-29-2015, 03:27 PM | #9 |
Consensus say prime it. Dont short cut it and take a chance. Timing is not even a close second to scoring a bearing.
Shawn 68 chevy K/20 05 chevy 3/4 4x4 71 short step-sold 71 chevy Beauville van My build. http://67-72chevytrucks.com/vboard/s...d.php?t=633039 |
05-29-2015, 03:34 PM | #10 |
05-29-2015, 05:19 PM | #11 | |
Timing it is really easy. Aim the rotor at number one cylinder and it will either be near 0 degrees BTDC or 180 out. If you don't like that method, most engines have a plug on the lower part of the block right above the oil filter. Remove that, hook up a small 12 volt pump (a boat fresh water diaphragm pump works really well for this) outlet to that spot with the suction side in a gallon jug of oil. Then you do't have to worry about getting the timing correct if it is already set correctly. That's how I prime all of mine. |
05-29-2015, 05:27 PM | #12 |
Thanks guys, I think you are right and I am going to do all of these.
My dad is very sharp with decades of experience but he's not an car restoration guy. I know you guys will walk me through any priming issues. Oh ya, I showed dad a youtube video on oil priming and he walked off saying "you'll end up doing this anyway and then you'll have to get the truck towed to a shop!" |
05-29-2015, 08:45 PM | #13 | |
All about them K’s
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
05-29-2015, 09:17 PM | #14 |
Is it possible for me to turn the crankshaft by turning the fan?
05-29-2015, 09:22 PM | #15 |
Not a good idea as you are putting undue stress on the fan blades. Especially if the engine is locked up. Turning at the flywheel is the better option. Front bolts and pry bar can work too. My favorite would be the crank shout socket which utilizes the key. But that involves a puller to remove the damper.
05-29-2015, 09:27 PM | #16 | |
05-30-2015, 11:39 AM | #17 |
05-30-2015, 11:56 AM | #18 |
I bought a two wheel drive blazer that sat under an oak tree for 15years it started right up no priming and ran for 50000 miles including towin a heavy overloaded trailer 1500 miles to florida in fact the engine was still running strong when i got rid of it with a blown tranny and noicy rear end
never did remove that dizzy for any reason
05-30-2015, 11:58 AM | #19 |
Yes prime it! I pulled the distributor on my 283 that had sat for 30+ years. The top end was dry, very dry and I'm sure the bearings were also. Put some oil in the cylinders and spun it around without the plugs in it. Fired right up and has run great since!
1955 GMC Hydramatic 1959 Chevy Spartan 100 1969 Chevy C/10 1969 Chevy C/30 Bruiser 1972 GMC (Wrecked) 1972 GMC pickup..old blue Restored Vent Windows https://67-72chevytrucks.com/vboard/...d.php?t=766598 1955 GMC hydramatic build http://67-72chevytrucks.com/vboard/s...d.php?t=429417 |
05-29-2015, 09:33 PM | #20 |
Good luck
05-30-2015, 12:08 PM | #21 |
How long does the eng have to sit before you guys recommend priming it? Over the winters I dont drive my blazer, should I be priming it when I pull it out in the spring? Once it sat for just about a year. should I prime it then?
Brad 72 Blazer CST 350/350/205 |
05-30-2015, 04:05 PM | #22 |
Ugh, dads can make it so difficult to love them. I fail to see how priming an engine can require a tow to the shop. Even if one could argue priming is not necessary, how can they argue it would do any harm?
Pulling plugs is especially important. Not only because when the mixture fires, there's a sudden down-force on potentially dry rod bearings, but because the cylinders and rings are also dry, the force of compression along will force the rings down and out against the dry cylinders. Even if the engine fires up and runs, how many thousand miles did you take off the service life of the engine anyway? Of course, there is still a chance the engine is already near the end of its service life. In which case, even under the best priming conditions, the engine fails less than a year later. This will confirm your dad's right in his mind, and you will never live it down. I've learned to ignore my dad over the decades. Regards, Mike
I own 3 classic vehicles. 1971 LWB C10 Deluxe. 1974 VW Super Beetle. 1971 VW Fastback. The C10 and the Super Beetle run, the Fastback is just not there yet! Please visit my Super Beetle and Fastback profile on TheSamba. |
