Old 05-30-2015, 07:10 PM   #1
sherm6413
Going price for factory tilt column
I've got one secured that will need repainted from factory 67-72 . $160 ,think I'm getting a decent deal ? I'm ok with the price. What do you guys think?
sherm6413 is offline   Reply With Quote
Old 05-30-2015, 07:18 PM   #2
Grumpy old man
Grumpy old man's Avatar
Re: Going price for factory tilt column
I'll take 3 at that price and I only need 2 . Better grab it before someone else does .
Old 05-30-2015, 07:21 PM   #3
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Last one I saw on the parts board here the seller wanted 300.00 and it came out out of a very rough truck. 160.00 is great deal.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 05-30-2015, 07:24 PM   #4
skrenly
skrenly's Avatar
Sounds to good to be true.
Could be junk.
skrenly is offline   Reply With Quote
Old 05-30-2015, 07:20 PM   #5
leddzepp
Moderator
leddzepp's Avatar
Be sure it's from a truck. Even if it's a van tilt, in great shape it's a decent buy if you need it.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 05-30-2015, 07:27 PM   #6
DeadheadNM
Carpe manana
DeadheadNM's Avatar
As a point of comparison, here's one now in good shape listed for $300 plus ship: http://67-72chevytrucks.com/vboard/s...7&postcount=74
Old 05-30-2015, 07:46 PM   #7
leftybass209
leftybass209's Avatar
Picked mine up restored for 400. I would suggest if you don't already know, to look for signs of it being an actual truck column, and not a van or rv. I don't know how many people at swap meets swear they have truck columns, when in fact, they're not.
leftybass209 is offline   Reply With Quote
Old 05-30-2015, 07:49 PM   #8
sherm6413
And what signs would I look for to tell if it's van or truck?
Old 05-30-2015, 07:59 PM   #9
leftybass209
An rv columns' shift selector at the bottom has 2 90 degree bends in it. The van column has a neutral safety switch located high up on column and the output shaft is noticeably longer than a truck tilt.
Old 05-30-2015, 08:40 PM   #10
FirstOwner69
FirstOwner69's Avatar
Top to bottom in picture below:
- RV. What looks like a tab sticking out near the shift linkage lever is just the clamp that goes to the engine side of the firewall.
- Truck. The firewall/floor seals are pushed up against back of the neutral safety switch in the picture. The van and RV columns also use different seals.
- Van
FirstOwner69 is offline   Reply With Quote
Old 05-30-2015, 09:20 PM   #11
FirstOwner69
Here's a link to a FAQ thread regarding how to modify the van columns. I THINK you only have to move the switch on the RV columns.
http://67-72chevytrucks.com/vboard/s...d.php?t=147927
Old 05-30-2015, 10:30 PM   #12
sherm6413
Thanks for all replies , too good to be true, it's actually an rv column.
Old 05-30-2015, 11:30 PM   #13
sduckworth13
sduckworth13's Avatar
Thats ok its still a decent deal at that price.
Scott
sduckworth13 is offline   Reply With Quote
Old 05-30-2015, 11:45 PM   #14
leftybass209
The column can still be modified to fit, but I'm glad you were able to figure it out. There's a lot of misrepresentation concerning parts for these trucks, either intentional or not.
Old 06-01-2015, 10:26 AM   #15
57larry
thanks for the picture ID. I think I bought a van column
57larry is offline   Reply With Quote
Old 06-01-2015, 11:17 AM   #16
gonnuts
gonnuts's Avatar
Van columns shafts can be cut & welded as well, then they are very hard to tell the difference. Then you will still have a collapsible shaft as well.
67 Chev SWB, 400 SB .040 over, vortec heads, comp XE268 cam, performer EPS intake, edel. 650 AVS carb, 700R4
gonnuts is offline   Reply With Quote
Old 06-01-2015, 12:42 PM   #17
hugger6933
That is a decent price for a RV column. It is a good way to get a tilt without breaking the bank
hugger6933 is offline   Reply With Quote
Old 06-02-2015, 09:35 PM   #18
CaptRMW
Custom Sport W/T
CaptRMW's Avatar
Location: Tarpon Springs,Fl & Annapolis,Md. ....................Quaint drinking villages with a fishing problem
If you hit something really hard you can find out what a joke the "Collapsible" shaft really is. My tilt came out of a beautiful Cheyenne Super that hit a very large 98 Oldsmobile head on and the lady driving the Cheyenne sheared off the aluminum trunnion in the upper part of the column with her chest as she was doing a final checkout. (yep it killed her graveyard dead) but it didn't collapse the lower shaft as it was the same length as others I checked. You probably have a better chance of winning the lottery that being saved from harm by the collapsible shaft. A block of wood and a big hammer will shorten the shaft so it will mate up with the van tilt. Take note of the effort to collapse it and think about doing that with your chest.
sherm6413 you are good to go, the RV columns that I have seen have the short shaft just like the truck column. Bolt it up and go.
CaptRMW is offline   Reply With Quote
