05-31-2015, 06:52 PM | #1 |
Aftermarket Air Pics
Can you guys post some pics of your aftermarket air kits and how they are mounted under the dash? I'm needing some glovebox pics for spacial planning. Trying to mount my LS computer somewhere under the dash and I'd rather not have to move it in a few years when I add a/c. So far the only good place I've found to mount it is on the driver side where the fuse block is located.....thus causing to relocate it when I put a new harness in. This is fine, however it will just look odd hanging below the dash like that. Plus I will have to remove the column if it ever needed to be taken out. Ideas...thoughts?
06-01-2015, 08:36 AM | #2 |
Re: Aftermarket Air Pics
I see them mounted under or behind the seat
06-01-2015, 09:47 AM | #3 |
I put my computer under the passenger seat, just have to splice and extend a 100 wires.
06-01-2015, 02:45 PM | #4 |
I just installed a Vintage Air in my 61...there is not enough room there behind the glovebox...either behind the unit and bolted to the cowl vent or in front of the unit as the Vintage Air unit makes you replace your existing glovebox.
I agree with one of the other posters, move it under the passenger seat and out of the way.. Tom
My Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=705185 How to Get Audiophile Sound in 60-66 Trucks http://67-72chevytrucks.com/vboard/s...=1#post7236896 Building Your Own Speaker Kick Pods http://http://67-72chevytrucks.com/vboard/showthread.php?t=730495 |
06-01-2015, 09:47 PM | #5 |
I'd like to mount it under the seat.....but I'm not going through that headache right now of lengthening all 100 wires. I need to get it fired up and running first and one wrong soldered wire would result in weeks of aggravation and scratching my head. I think I've found a great place under the dash between the radio and the steering column.
06-02-2015, 08:36 AM | #6 |
I cant figure out how to share one of my post....search (Vintage A/C dash)
