Old 05-31-2015, 10:29 PM   #1
69heavychevy
69heavychevy's Avatar
Pitman arm removal nightmare
Thought I'd share what it took to remove my pitman arm.
I removed the steering gear from my 80 C10 to re-seal the leaking input and output shafts.
It looked to be the original pitman arm and to my surprise it was still good. Had planned to replace it with a moog unit, but in the end decided to re-use it.
Had never had such a difficult time removing a pitman arm before, I used a 24" breaker bar combined with a 24" cheater pipe...
80 C10 SWB Step Side - 350 w/ vortec heads, TH350, 12-bolt 3.73
69heavychevy is offline   Reply With Quote
Old 05-31-2015, 10:41 PM   #2
esbstuff
Re: Pitman arm removal nightmare
??? I never used a puller on anyone I have ever changed. One swift hit from a 2 pound hammer takes them off in no time. One that was real bad I had to hit 3 times...
esbstuff is offline   Reply With Quote
Old 05-31-2015, 11:20 PM   #3
1970pelle
1970pelle's Avatar
I have had to use a little bit of heat while having pressure from the puller still on there. It will pop loose after a short time of heat applied to the outer edge of the pitman arm. And you will be able to reuse it after a good clean up.
Ken
1985 IROC Z28 190HP TPI 305,700r4,T-tops,rear trac lock, Black on lite gray, 16in Z28 wheels
2007 Lexus ES350 (wifes)
1984 CJ7 with 1995 HO4.0L MPI, 2 1/2 OME YJ Lift
“There is no limit to the amount of good you can do if you don't care who gets the credit.”
― Ronald Reagan
1970pelle is offline   Reply With Quote
