06-01-2015, 03:48 PM | #1 |
Rear Axle conversion on a 68
Can I swap a 5 lug rear axle out of a square-body Chevy into my '68 C10?
06-01-2015, 03:57 PM | #2 |
Its a Truck Thing......
Re: Rear Axle conversion on a 68
All depends,
Leaf or coils? If I recall, square bodies were all leaf springs, (could be wrong) you will have to deal with the perchs, but the axle can be made to fit if you have coils. Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 71 C20 Longhorn/Ole Yellor 69 C30 Former Motor Home, Flat Bed time |
06-01-2015, 05:59 PM | #3 |
You can buy a axle install kit from most any vendor to put a regular rear end in the coils sprung truck. They cost about $150 I think I was gonna look into one but have since founds some coil sprung axles that are 5 lug.
06-01-2015, 06:22 PM | #4 | |
Go here: http://67-72chevytrucks.com/vboard/s...d.php?t=558016 Download the PDF of the Chassis Overhaul Manual for your truck. It will show you how to remove the axles and install new ones. It's an easy process. Remove the wheels and brakes, remove the rear cover, remove the retaining pin in the center section. Slide out the 'C' clips pull the axles out. Then reassemble in reverse order. You won't need to change any adjustments because you didn't change any. It's also a good time to inspect the internals. Things wear a bit in 46 years! The last time I did this I acrually did get it done in 45 minutes! |
