06-02-2015, 07:40 AM | #1 |
Vintage Air kit..............worth it?
Just wanted to get a few opinions on here to see if people feel that the Vintage Air kit is worth the 1400 bucks you pay for it. I currently have no a/c in the truck (evaporator and condenser were removed when i got it) and the hot muggy Florida summers are upon us. So an a/c would be really nice to have?
Also how would i know if my truck orginally came with a/c? It has the vents and controls on the dash, but I wasnt sure if that a dead giveaway. Oh and this is going into a 76 K10. |
06-02-2015, 08:23 AM | #2 |
Re: Vintage Air kit..............worth it?
any photo(s) .. ?
dont want to hear excuses, i want to hear solution(s) |
06-02-2015, 08:41 AM | #3 |
I installed VA in my 77 C10 over the winter. It's not my daily driver and only gets driven to cruise in's/car shows. I can say without a doubt that it was worth it to me. 20 years ago i could stand not having AC. Never again...
Installation was very straightforward as long as you follow the directions. It took me WAY too long to install mine but I would say it could be done easily in 2-3 weekends or 2-3 days straight.
77 C10, 6.0LS/4L80E, 3:73 12 bolt. Boss 338's 20" x 10" w/ 285/50/20 rear. 20" x 8.5" w/ 245/40/20 front. Vintage Air. Full Autometer gauges recessed in factory bezel (Thanks bigblock73!) Gm Storm Grey Metallic paint "Cool ain't ever cheap and cheap ain't ever cool" |
06-02-2015, 12:35 PM | #4 |
Gentleman Jim owner x2
Why not just go to the junkyard and grab all the a/c stuff off a parts truck?
Easy way to tell if your truck came with a/c is by the fan box. If it hugs the firewall and just has heater lines going to it, it's a non-a/c cab. If it has the box for the evaporator, sticking out by the passenger manifold, then you have an a/c cab.
1975 GMC Gentleman Jim #1 -357 / 700r4 1975 GMC Gentleman Jim #2 -350 / TH350 |
06-02-2015, 03:16 PM | #5 | |
06-02-2015, 03:40 PM | #6 |
Pros:
Cons:
All in all, I'd still do it again. |
06-02-2015, 04:01 PM | #7 |
I don't have VA, just stock a/c, but I do like the idea of all electronic controls on the new version of the VA kit. The vacuum controls on the stock system (and all vacuum controls, as far as I am concerned) are always of questionable operation with the stock system. In this modern era, I see no need for vacuum controls - just electronic. From what I read, for maximum cooling, the old R12 systems are the best, but the compressors do leak. My old R12 1976 C20 was the coolest A/C I have had yet.
06-02-2015, 04:13 PM | #8 |
Im on the fence for many of theses same reasons with i could find one for 1,000 ha ha
06-02-2015, 02:45 PM | #9 |
One reason to go with the VA kit over a stock system is that the entire VA kit is contained in an airbox behind the firewall, so there is no big box for the evaporator under the hood. Cleaner underhood look.
Rich Weyand 1978 K10 RCSB DD. |
06-06-2015, 03:57 PM | #10 |
I just did this on my 84 K10 w/out A/C and did video the whole way. It was super easy to install myself, the only thing I had to have someone else do was crimp my hoses and evac/recharge it. My kit was a little bit more because I had to also get a high mount for the compressor since I have an LS in the truck. It worked great the other day when it was 95 outside, I'll really put it to the test when it's 120 and I'm idling through the desert
Here is my build thread, starts about post #84 http://67-72chevytrucks.com/vboard/s...11#post7194311 Last edited by whitels1; 06-06-2015 at 04:03 PM. |
06-07-2015, 10:09 AM | #11 |
I have been running Vintage Air in my truck for about 2 years now. It has been flawless. Ice cold in the summer and heater works good in the winter.
06-07-2015, 12:17 PM | #12 | |
After all my experience with them over the years, I'd say these factory AC systems are problematic. You need a good AC tech to keep them going for more than one summer at a time. Mine keeps finding a new way to leak every year. |
06-06-2015, 10:01 PM | #13 |
1400 for a brand new ac system sounds like a lot but its not.I have seen people spend more to repair a ac system on a newer car/van before.
07-08-2016, 12:34 AM | #14 |
Yes, worth it. I just finished my own install of a Vintage Air (VA) A/C system in my '70 C10 which did not have factory air. It's summer and I live in Las Vegas. I had a local A/C shop do the evacuation and charging, and no leaks. It blows really cold and large volume air, fan speed is variable. Great decision. Getting the ducting in under the dash was a bit sporty but doable. They provide very soft flexible ducts which really helped. Well worth the money. It requires five different metal drill sizes and removal of the right front fender which I replaced with a new one since it was only $80. The VA instructions are very good.
While I was at it, I installed an aluminum radiator and new pulleys. The whole job took me about 4 full days over three weeks. |
07-08-2016, 07:19 AM | #15 |
My 87 uses the factory system converted to R134. Will literally freeze you out of the truck. You need the long compressor on the conversions, the radial compressors are too small. Sandeen versions seem to be small but they are more efficient so they probably do OK.
1987 2 ton 1982 250/TH350 beater in progress Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping Plus a mess o' tractors |
07-08-2016, 08:14 AM | #16 |
My 87 has factory a/c, but I was looking into the Vintage Air stuff, just so that everything was new. I guess their kit doesn't work with an 87 though, for some reason. Just the 73-86. So, that pretty much made up my mind for me.
1987 R10 Silverado "Farm Fresh" Build http://67-72chevytrucks.com/vboard/s...d.php?t=703698 |
07-08-2016, 09:01 PM | #17 |
I just installed a VA system in my 87. Super easy and man that thing will freeze you out of the cab. I also bought the Alan Grove brackets to swap my alt. to the l/h side and a/c comp. to the r/h side. It is a great system, the Sanden comp. has less patristic drag and is very efficient. You will not be disappointed with the VA setup !
84 step side 87 swb |
07-08-2016, 11:12 PM | #18 | |
07-09-2016, 09:21 PM | #19 |
I asked Vintage Air why they don't advertise that the kit will fit an 87'. The guy I talked to said that the under dash unit may interfere with the mounting location of the stock computer. My cab is an 83', but I'm running TBI from an 89' Suburban. I was able to fit the computer on top of the Vinage Air unit.
07-09-2016, 10:39 PM | #20 |
It is a tight fit but I unplugged my harness plugs on the ecm, then I installed the front two mounting screws on the a/c unit then plugged it back in.
07-09-2016, 02:18 AM | #21 |
78 Big10 454
I installed a VA A/C kit in my 72 Burb. Gets so cold I could hang meat!
1978 Chevy SWB C-10 2WD 454/400 |
07-09-2016, 07:44 AM | #22 |
Yes they have a system for the 87's. Call them and they will set you up. Order through Sumit Racing ( free shipping ) It really cleans up the firewall and looks great. I am about to wash my truck and I'll snapped some pics of the firewall.
07-09-2016, 12:45 PM | #23 |
Engine bay
07-09-2016, 01:35 PM | #24 |
Is this the kit shown in your pic? I am also curious about the posting that commented about the system being "Noisy".
I have thought about this upgrade on my 87. Desert |
07-09-2016, 08:28 PM | #25 |
That kit looks a little different than mine, give me a second and i'll run out to the shop and find the correct # for my kit. As far as being noisy if its on full fan it can be a bit noisy but that's what the radio is for, plus when it's 100 degrees outside I really am only concerned with staying cool. Again worth every penny !
