06-02-2015, 02:41 PM | #1 |
What intake is this?
I'm trying to identify what intake is on the truck. The engine block cast number and engine code number tells me that I have a 1975 350 CID L48. But I suspect that the intake has been changed along the way.
Currently there is a spread-bore Q-Jet (edelbrock 1902) setting on with a home made plate. |
06-02-2015, 02:54 PM | #2 |
Re: What intake is this?
From a mid sixties 327.
http://macswebs.com/cddemo/66cd/etr/engines/intake.html |
06-02-2015, 03:06 PM | #3 |
Thanks. I think I need to dig a bit further. I will post the real casting numbers later tonight.
My intake doesn't have the front oil filler. The picture I provided was one I found on the web that shows the same bore pattern and EGR path (I think EGR). |
06-02-2015, 04:27 PM | #4 |
member #16
scroll down for intake casting no's. I cannot read the no's clearly.
http://www.nastyz28.com/sbcmenu.php
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors http://www.flickr.com/photos/1745471...7602865984234/ |
06-02-2015, 06:44 PM | #5 | |
He found that pic for reference. It's not his intake!! |
06-02-2015, 04:37 PM | #6 |
don't know what it comes off of but one of the best intakes i ever used, bolt a standard bore holley straight to it, but i think geezer is right came off a 327
"Send in the clowns the goats are loose" |
06-02-2015, 05:28 PM | #7 |
subbed
1967custom |
06-02-2015, 05:34 PM | #8 |
Pretty sure mid 1960's is correct and made to accept a Rochester 4-jet
06-02-2015, 05:57 PM | #9 | |
But to be honest just looks like a standard cast iron intake off a 305/350 truck. |
06-02-2015, 05:59 PM | #10 |
It's not a spread bore so it's not from the Quadrajet era
06-02-2015, 07:57 PM | #11 |
The numbers on MY intake are 3927184.
Posted via Mobile Device |
06-02-2015, 08:07 PM | #12 |
#3927184 comes out as '69 350 Q-jet intake. Are you sure the bore pattern is as the image you shared above?
06-02-2015, 11:41 PM | #13 |
Yes. But when I take off the carb I will post a photo. Was there ever a square and spread board Q-jet?
Mine is a early q-jet with a edelbrock label and taged as 1902. Posted via Mobile Device |
