Old 06-02-2015, 07:42 PM   #1
bigbadchev72
People know me
bigbadchev72's Avatar
Old gas
My blazer has been sitting for a few years and I have recently pulled it out of hibernation. It had a little under 1/4 tank when parked that went bad. it still started, but smells awful. I let it idle until it ran out of gas and then filled it up.
This thing still stinks like an old junkyard car when it is running. Is this gonna go away after a couple tanks or do I need to have another plan of attack?
1972 k/5 blazer CST 4X4 Crate 350, th350/205, dana44with trac-loc/14 bolt with detroit locker, 4 wheel discs 4.56s, 8" suspension lift using 73-87springs, 1" zerorate custom front crossmember, HAD CV drivelines and driveshaft e-brake, full cage, PRP seats, Full autometer gauges, 38x14.5x16 Toyo M/Ts, 16x10 Polished aluminum rockcrusher wheels
1967 longbox 4x4, Strong 400/400/208, 44/12bolt 4.10s, 6" lift, 35" Toyo M/Ts on corvette rally wheels
bigbadchev72 is offline   Reply With Quote
Old 06-02-2015, 07:52 PM   #2
Jurassic-1
Jurassic-1's Avatar
Re: Old gas
Be careful of old gas. My Blazer had 10,000 miles on a rebuild and I had 4 gallons of old gas to 14 gallons of fresh gas it ran ok at first and the next day it missed a bit and by the following day it pushed 5 rocker studs out. I usually will drain and clean the tank and flush fuel lines then rebuild the carb before starting a vehicle that has sat. I am very gun shy now. If you already have it going you can use Seafoam in the gas and oil or just put about 1 quart of ATF in the oil and let the engine idle for awhile this will help lubricate and clean any varnish that may be on valve guides or other internals. After a bit of running dump the oil and filter and add seafoam to the oil and you should be good.
Jurassic-1 is offline   Reply With Quote
Old 06-02-2015, 08:22 PM   #3
GRX
GRX's Avatar
Re: Old gas
Yeah. Gummed up valve guides can wreak havoc. Don't you just love that Turpentine smell? At this point you have probably removed much of it from the system. For cleaning old gas varnish out of the tank my vote goes to a gallon of Acetone. Run that into a can not the engine, then fill the tank with good gas and drive.
GRX is offline   Reply With Quote
