Old 06-02-2015, 08:36 PM   #1
Sammys70
Sammys70's Avatar
break-in overheating, Help
just searched some old threads but wondering if you guys could come up with other ideas or point me in right direction
heres what i have:
new basic gm crate 350
comp262 cam with 981 springs
duel electric fans
180 themostat that I drilled two small hole in and bench tested !
I manually am turning on fans before I start up!
now trying to break in cam but as I get to 5min or so it overheats
seems like i'm getting flow in radiator
radiator tanks are hot, but I get hold my hand on front of radiator
lower hose is hot but I can touch
top hose is hotter than hell and very firm
I'm leaning towards air trapped in system but feel like I should have got it out by now
gonna try running without thermo tomorrow
any other advice would be nice, I can't wait to drive it!!!
Sammys70 is offline   Reply With Quote
Old 06-02-2015, 08:50 PM   #2
hotroddin
hotroddin's Avatar
Re: break-in overheating, Help
Air in the system. Take your thermostat out and fill from there, leave the radiator cap off as well.
71 c10 350 sm465 - sold
71 c10 305/th350 - dd
hotroddin is offline   Reply With Quote
Old 06-02-2015, 09:58 PM   #3
FirstOwner69
FirstOwner69's Avatar
Overheats as in the gauge says it's really hot or does it boil over? Just a reminder that the stock radiators without an overflow tank are to be filled only to about 3" below where the cap seals.
FirstOwner69 is offline   Reply With Quote
Old 06-02-2015, 10:06 PM   #4
Sammys70
Sammys70's Avatar
Definitely overheating, only had light go off once and that's when I pushed it trying to get the air out that I still think I have.
Just finished taking thermostat out and will leave level down a bit
Gonna try tomorrow
Old 06-02-2015, 10:21 PM   #5
FirstOwner69
Old school heads or Vortec? A/C? Where's the temperature sensor? Is it your original? Sounds like you don't have a gauge dash, and you are basing the overheat condition based on a warning light Correct?
Old 06-02-2015, 10:38 PM   #6
sduckworth13
sduckworth13's Avatar
Just curious how long did you run it for after it exceeded 180? As soon as mine hit about 210 we shut it down and just tried to purge the air by squeezing the radiator hoses, fired it back up and it went to roughly 215 a few nervous seconds and then shot back down to a steady 180.
Scott
sduckworth13 is offline   Reply With Quote
Old 06-02-2015, 10:52 PM   #7
Sammys70
Sammys70's Avatar
No a/c, old school heads, temp light only, with new sensor. Saw light once and was shutting it down as I saw it so not long. It's an overheat and not a sensor, I have lots of steam and scorching hot radiator fluid.
Old 06-02-2015, 10:58 PM   #8
46stude
Got initial timing set w/ a light?
46stude is offline   Reply With Quote
Old 06-02-2015, 11:10 PM   #9
Sammys70
Sammys70's Avatar
Yeh. Set at +11
Plugs at .045
Starts and runs great
Old 06-02-2015, 11:38 PM   #10
Acorn
Double check timing and air in system. Do you have your heater hoses hooked up? It would be really good if you could get a test gauge so you can see exactly what the temp is and if your t stat is opening.
Really dumb question but, are the fans blowing the correct way? (I ask because I've put one on backward once!) do they have a shroud? Do they feel like they are blowing good?
Be extra careful to not overheat a new eng. you could collapse your rings....
The bitterness of poor quality lingers long after the sweetness of a low price is forgotten.
Acorn is offline   Reply With Quote
Old 06-03-2015, 05:23 PM   #11
68350
68350's Avatar
For my camaro I just went to O'Reillys and grabbed a 3 guage pod. Alt, temp, and oil pressure. 50 bucks or so and its a breeze to put in. Guages are autometer. A brand new fresh motor will probably run a lil warmer than normal just because all the tolerances are tight. Once it breaks in should run normal temp. What degree thermostat did you put in?
68 Chevy CST/10, 50th Anniversary, 327/th400, 373 posi, buckets
68 GMC Shortbox Stepside, 402/th400, Tilt, Tach, Bucket Seats, 3.08 Positraction
69 Chevy Camaro SS, 383, 4 speed, positraction
70 Chevy El Camino SS396, Triple Black, 454/th400, Tach
70 Chevy Shortbox Stepside 4x4, 350/th350, Tilt, Tach, Cab Lights, Bumper Guards, Tow Hooks
70 Chevy 3/4 Longbox, 350/auto, 70k, SURVIVOR
71 Chevy Blazer, CST, 350/auto
71 GMC Sierra K2500, 454, 4 speed, 4.10 posi, 37s
71 Custom/30, Open Road, 350/th400, tilt
72 Chevy Shortbox Fleetside, 496 Stroker/th400, Tilt, Tach, Bucket Seats, 3.42 Posi
72 GMC Sierra Grande 2500. 427/th400, tilt, a/c, tool and stowage, buckets/console, 3.54 posi
68350 is offline   Reply With Quote
Old 06-03-2015, 07:19 PM   #12
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
11 degrees advance is not a lot of advance timing. Even for a stock engine. With the 262 cam even 14 degrees advance will be good. Is it the old original balancer? Is the timing mark on the balancer correct? If you have timing too far retarded it will run hot. It can run so hot it will make the exhaust manifolds glow orange.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 06-03-2015, 07:33 PM   #13
geezer#99
geezer#99's Avatar
X2!!
I run 14 initial with a stock 305.
Have run 22 with an 11 to 1 aluminum headed motor.
Running well below optimum timing is like pouring one gallon of gas on the ground when you put 10 in the tank.
Old 06-03-2015, 09:42 PM   #14
Sammys70
Sammys70's Avatar
Well I'm definitely not an expert on timing. Had my friend who has lots of experience set it and I trust him. Although we will check again. It's was a new balancer which was put on by machine shop that installed cam. Will know more once I get temp gauge hooked up.
Old 06-03-2015, 10:10 PM   #15
GASoline71
GASoline71's Avatar
Timing with a timing light? Or winging it?
Gary
Old 06-03-2015, 10:15 PM   #16
Grumpy old man
Grumpy old man's Avatar
are you using a good break in oil to start ?
Old 06-03-2015, 10:32 PM   #17
Sammys70
Sammys70's Avatar
With a light
Used brad penn break in green oil
Old 06-18-2015, 08:58 PM   #18
Sammys70
Sammys70's Avatar
Just wanted to update this in case anyone else has a problem in the future.
Turns out it was the radiator.
My "old" one looked good, inside and out, but I suspected some flow issues and I finally caved in and bought a cheap a369 from autozone, now it's right at 180*.
Thanks again for all the suggestions
Old 06-18-2015, 11:11 PM   #19
Sklptrljay
Sklptrljay's Avatar
Glad you finally got it going. I hate when crap like that happens.
You wonder if you spent all that money and time for nothing. Really creates some serious pucker factor in your BVDs.
1971 C/10 SWB, 15x8 Rallys, 4.5" X 7" static drop, C-notched, 350/350, 3.73 Posi. .........A 383 and Gear Vendors are on my bucket list.
1972 GMC 4X4 K1500 Survivor - Sold
No matter what problems life throws at you, your time on Earth can be incredibly fulfilling and rewarding.....if you just lower your expectations. -Phil Dunphy
Sklptrljay is offline   Reply With Quote
Old 06-19-2015, 08:26 AM   #20
VWNate1
VWNate1's Avatar
Post Re: break-in overheating, Help
Before tossing the old radiator , give it a citric acid flush , that cleans better than anything else I've ever used .
-Nate
Geezer
'49 3100 235 W/ Muncie SM420 SOLD
'69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH
VWNate1 is offline   Reply With Quote
