06-03-2015, 04:01 PM | #1 |
Moving spring mounts down
I'm in the process of lifting my 64 K10 and got the rear sitting where I want it. I used 63" rear springs and got about 6" of lift. Now I'm working on the front using 52" springs. I've moved the front mount forward and the rear back, I'm wondering what the drawbacks would be to putting a spacer between the front spring mount and the frame to get it sitting level with the rear. I plan to gusset everything and am using grade 8 bolts everywhere.
Aaron 1964 K10 1964 C10 1965 Suburban 2005 Yukon |
06-03-2015, 04:58 PM | #2 |
Re: Moving spring mounts down
i dont think you'll get any issues with using a frame mounted lift bracket for the shackles. Curious, how many leafs are in your 63" pack to get 6"s of lift in the rear? what mounts did you use? shackle flip?
Steve 1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's |
06-03-2015, 05:04 PM | #3 |
The 63's have 4 leafs plus the overload. I used the brackets off an 87 Suburban, no shackle flip. Before I switched everything out, my wheel opening was 33" from the ground, after I measured 39" with the same wheels and tires.
06-03-2015, 10:48 PM | #4 |
Cool idea with the front mount. I did that exact thing years ago to a 77 cclb dually. It worked fine. I put a lot of miles on that set up.
So it sounds like you used 3/4 ton 63"s? That's a lot of lift without a flip. Are they stock springs?
Chris '63 k15 long step Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205 52" front and 63" rear spring swap D44 / 14bff - disc axles Milemarker 9K and 10.5K hydraulic winches 63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29 |
06-04-2015, 09:24 AM | #5 |
They are stock springs off a 99 1/2 ton Suburban 4x4.
06-04-2015, 09:30 AM | #6 |
interesting, thanks for the info.
im looking at doing a 52/63" spring swap as well but i dont want that much lift.
06-04-2015, 09:35 AM | #7 |
I'm using the stock 64 lift block. A shorter block could be used to bring the rear down.
06-04-2015, 11:41 AM | #8 |
As long as you brace it across the frame to each other it should be fine.sky manufacturing uses the same idea but bigger for a lift kit for the front the later 4x4s.
06-04-2015, 11:55 AM | #9 |
Excellent. I am going to use 2x3 box for the spacers and probably 2x2 box for the cross brace.
06-05-2015, 09:28 AM | #10 |
06-07-2015, 05:18 PM | #11 |
My plan is to take a 6" long piece of 2"x3" .125" wall box tube, weld and bolt it under the frame on each side, then weld a length of 2"x2" .125" wall box tube between the frame, sorta like a crossmember to hold the 2"x3" in place and keep them from bending in or out. I'll get pictures once I get everything in.
06-05-2015, 09:11 AM | #12 | |
06-07-2015, 11:59 PM | #13 |
1/8" wall tube seems a little thin to me. I would use 3/16" wall thickness minimum.
Jason M. @argonaut62 1972 K5 Blazer CST, Turquoise 1966 K20 Short Fleet Pickup, Big Ugly 1964 C10 Short Fleet, Gertrude 2001 Porsche 911 Carrera 1996 Ford Bronco XLT 1980 Jeep Wagoneer 2008 Honda CBR1000RR 2005 Honda RC51 1981 Honda CB750C No dis-assemble Johnny Five! No dis-assemble! |
06-08-2015, 12:01 AM | #14 |
Also I wouldn't run that huge block in the rear. Axle wrap on the springs will be way worse given the longer length. I'd go with a shackle flip instead to get that lift in the rear.
These are just my opinions.
06-09-2015, 02:22 AM | #15 |
What i mean by a cross brace is just some kinda brace across the frame from spring hanger to spring hanger.Its a little over kill to some but i rather do things once and not fix something later on.And while you got it apart make sure you got a steer box brace if not make or buy one.
06-09-2015, 11:40 AM | #16 |
I've seen what you are talking about. Mostly, I seen it used by those who run 56" springs on the front; the hanger gets pushed out to the end of the frame horn to accommodate the spring length but this puts too much leverage on the horn for twist and bend so they link both hangers together with box tubing.
06-10-2015, 01:20 AM | #17 |
Looks like this http://www.sky-manufacturing.com/cgi...CHEVY-SAPD-004 The front is a crossmember/spring mounts but same idea can be made at home.
06-10-2015, 10:57 AM | #18 |
that's the critter
06-19-2015, 03:43 PM | #19 |
06-19-2015, 03:55 PM | #20 |
Here's where I'm at as of now. I still have to get longer bolts, weld in tubes and cap the ends, but I wanted to make sure it would sit where I wanted it to. I also need to add another gusset from the hanger to the frame.
And here is how the truck is sitting in mockup. Please excuse the mess.
06-19-2015, 04:22 PM | #21 |
Thats what my garage looks like after a day of work..good job on the crossmember.What springs are you using?
06-19-2015, 04:36 PM | #22 |
They are of the 52" variety from the back of an 87 Suburban 1/2 ton.
06-20-2015, 10:01 AM | #23 |
once you have that hanger gusseted in, you will have a good platform to build off of for a bumper, winch, plow, or a combo of all 3!
