Old 06-05-2015, 04:11 PM   #1
Evoracer
Bag recommendation
'63 C10 LWB. Currently static dropped 4.5/7.5, 3" notch.
Will Schrader/bag rear only. Looking for a bag that will ride nice that is not too bouncy as the rear will ride mostly at one low ride height. Firestone 255c, D2600's, others?
Thx
Evoracer is offline   Reply With Quote
Old 06-05-2015, 06:33 PM   #2
tinydb84
tinydb84's Avatar
Re: Bag recommendation
If you are putting them in the stock spring position then any double convoluted bag should be fine. An 8'' bag will be softer. If you plan on riding low and don't want a lot of bouncing look into a shock relocation kit and good shocks as that will have more effect on ride quality than your bag.
David
Instagram: myfabguy
Old 06-08-2015, 12:16 PM   #3
SCOTI
SCOTI's Avatar
How was the rear drop achieved?
What type of rear suspension set-up do you have?
This info plays a part in recommending rear bags in a specific application.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 06-08-2015, 12:51 PM   #4
Evoracer
Thanks guys...
Trailing arm suspension, 6" spring, 1" block, 1/4" of panhard bar mount, 6deg pinion wedge.
Will go to a 2" block when bagged. Have already relocated shocks.
Old 06-08-2015, 01:08 PM   #5
SCOTI
SCOTI's Avatar
Originally Posted by Evoracer View Post
Thanks guys...
That set-up would work well w/a 6" or 7" dbl convoluted bag. The smaller diameter bag would get you closer to optimal pressures (as suggested by the bag mfr's).
That would be Slams RE-6 (or current equivalent) or Firestones 267c/F6781. The 7" bags (or larger) would work but pressure would be very low (30psi or so) which will impact ride quality. I found that when I used the 7" bags on my 68 that was set-up similar to what you have (1.5" blocks, bolt-in c-sections w/no bump stops, relocated shocks, aftermarket Panhard bar) that the ride was too bouncy. I swapped to a taller block & 6" bags. This required more psi for the same height desired which yielded better ride quality.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 06-08-2015, 01:14 PM   #6
Evoracer
Thumbs up Re: Bag recommendation
Exactly what I was looking for. Thanks.
Old 06-08-2015, 01:16 PM   #7
SCOTI
SCOTI's Avatar
Ride height on 29" tall rear tires @ approx 40psi....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
