Old 06-06-2015, 05:25 PM   #1
'63MurderTruck
'63MurderTruck's Avatar
Max Rear Wheel 'Width' - '63 Stepside
Anyone know the max rear wheel width and tire size for a '63 Chevy stepside with a stock 12 bolt rearend without having to tub it?
What offset and backspacing, also?
'63MurderTruck is offline   Reply With Quote
Old 06-07-2015, 01:37 AM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Max Rear Wheel 'Width' - '63 Stepside
I'm pretty sure I have the widest rear setup on the forum for a standard frame (though its possible a member with a 17" wheel could go about 2/3" wider if they could find a rim that existed that size). I have a 12" wide beadlock and 325/50/15 Drag Radials on my '66 with a 71 12-bolt. While my truck is tubbed (too much actually lol), its not on a narrowed frame or anything. My tub only needs to be about 2.5" but is over twice that.
It requires custom built wheels, with over an 8.5" backspace. Most companies don't do over 6-7" BS, so you're stuck having them built, or finding something like a WELD drag wheel.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 06-07-2015, 05:35 PM   #3
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Since :
Old 06-07-2015, 07:08 PM   #4
Joe Pass
Joe Pass's Avatar
I run a 255/70/15" on a 8" steel wheel with a 4.5" backspace...
That is the biggest tire/wheel combo I can fit on my 62 stepside..
My rear end is a donor from a 64 C10 which if I'm not mistaken is the same dimensions as yours. When said and done the tire has 3/8" between the untrimmed fender edge and 5/8" to the bedside...I have no rubbing issues and I'm able to tuck the tires up in the fender. In my case that's about as much as I'm going to get with out tubs...........Good luck, Joe
Joe Pass is offline   Reply With Quote
