Axle mods while out
I am in the process of changing my rear axle bearings and seals. While I have the axles out is there any modifications recommended before re-installing them? I want to keep the 6 lug axles and I am in the process of pricing Torque Thrust ST's. Is the bore size an issue on the rear centering ring?
![]() Join Date: May 2013
Re: Axle mods while out
possi ,, and disc brakes are nice add ons
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs 67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive 58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white 69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive |
I would do possi also.
..................... ____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1970 C20 -_--_--_- ______ _--_--_- /___|__\____ -_--_-_ |_(0)|__|_(0)] 1972 K5 |
![]() Join Date: Oct 2004
Defiantly do a posi or limited slip! Also a new ring and pinon gear. That is what I did when I rebuilt my rear axle.
Steven 69 Chevy C10 Suburban 350 700R4 w/Disc brakes on all four corners ![]() 2017 50th Anniversary Camaro SS 2004 Chevy Impala LS 2016 Chevy Malibu LT |
#5 | ||
"I ain't nobody, dork."
Limited slip = Posi-traction
![]() An Eaton Posi-traction unit will be the best $400 bucks you can spend on your truck. Gary
I thought Posi-traction and a limited slip are different! Where a posi has issues when you make turns but a limited slip corrects that issue by allowing the inside wheel to slip when turning.
One of the First
![]() Join Date: Jan 2000
Limited slip is locked like a full posi unit, until you turn and then internal clutch pack will let one axle slow or speed up with the turn or terrain undulation. Nothing like hearing a full posi "POP" while turning or backing. it will sound like you just blew your rear end.
DAVID PASSMORE ST AUGUSTINE ,FL ZIP 32084 '71 SWB K/10 CUSTOM DELUXE (Chili) '72 BLAZER K/5 Muscle Truck (Mule) '72 LWB K/20 CHEYENNE (Blackie) |
![]() Join Date: May 2003
An Eaton posi / limited slip has clutches that slip for cornering. A locker has no slippage and will chirp tires on corners.
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 |
#9 | ||
Limited Slip diffs by different names... all the same thing.
Chevrolet = Posi-traction Buick = Positive Traction Olds = Anti-spin Cadillac = Controlled Traction Pontiac = Safe-T-Track Ford = Traction Lock Chrysler = Sure Grip AMC = Twin-Grip ![]() Gary
Assuming you have a stock cover, I would add a drain plug bung while you have a it off.
http://www.chassisunlimited.com/stor...rain-plug.html |
