06-09-2015, 05:45 PM | #1 |
New shoes
Got some new shoes on today.
06-09-2015, 06:38 PM | #2 |
Never Ending Projects
Re: New shoes
Nice! Looks great. I SOOOO need to get my panel on the road!
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
06-09-2015, 10:25 PM | #3 |
Re: New shoes
Looks Great Man!!I got to get a panel one day....
06-10-2015, 08:06 PM | #4 |
Re: New shoes
Looks great!- more pics and info on your wheel/tire setup please
66 GMC Suburban Custom 66 Chevy K10 Suburban |
06-13-2015, 12:19 AM | #5 |
Re: New shoes
Tires are 225/60/18, not too low profile, I didn't want too much of a rough ride, these have enough rubber and ride nice.
The wheels are Mobsteel. 18x8 with a 4.5 backspace. I almost went with the 20", but I was concerned with clearance but I think they would have fit well. Ill run these for now, I like how it handles and drives and the stance isn't too crazy either way. |
06-13-2015, 09:44 AM | #6 |
Re: New shoes
I'd say you nailed it with the complete package, paint scheme, stance and wheel tire setup, your panel really stands out - great job!
07-11-2015, 02:57 PM | #7 |
Re: New shoes
Looks Great! I'm getting ready to make a order from Mob Steel for my 66 GMC Panel. I'm wanting to go with the 20's. Question: Have you lowered your Panel, if so how many inches in the front and back?
I'm dropping my 4 inches all the way around and want to make sure I will have enough clearance with those rims with a tire package of 255/45/R20. Any insight would be appreciated. |
07-13-2015, 11:32 PM | #8 |
Re: New shoes
Leon I dropped it 5 in the rear and 3 up front. I was considering 20's but thought I might rub, but I think they will fit just fine. Your going with a pretty low profile tire so that will help too. I didn't want too rough of a ride and it doesn't, drives better than some newer vehicles I have and handles great. I did the drop spindle and shorter spring route by the way, not just cut or shorter springs
07-14-2015, 05:46 AM | #9 |
Re: New shoes
Thanks for the reply and suggestions. I am also going the drop Spring and Spindle route from CPP. The drop spindle they offer is supposed to pull the front wheels in on both sides 3/4 for a inch to help ensure no rubbing when running larger wheels and or tires. Just curious, what is the measurement (Clearance) from the ground to the front lip of wheel well? 29 inches?
07-15-2015, 11:26 AM | #10 |
Re: New shoes
With my wheel tire setup the front is sitting at just a shy over 28" and the rear at 24. Springs are fairly new, so I'm guess over time they might sag a little bit?
07-17-2015, 10:19 PM | #11 |
Re: New shoes
do you have any close up pics of the wheels
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
07-21-2015, 08:51 PM | #12 |
Re: New shoes
Here you go
07-21-2015, 08:53 PM | #13 |
Re: New shoes
And another
09-14-2015, 09:29 PM | #14 |
Re: New shoes
Quick question, you used CPP parts right? I used their 2 inch drop Spindle and 2 inch drop springs and barely got a 1 1/2 total drop. Trying to figure out if there was some sort of problem with the parts they sent me.
09-15-2015, 07:05 PM | #15 |
1960 GMC Burb
Re: New shoes
Beautiful ride ! Great job !!
1960 GMC Suburban 1/2 ton V-6 2nd generation original owner 60 Burb Build thread: http://67-72chevytrucks.com/vboard/s...=1960+Suburban 60 to 66 Burbs only Thread: http://67-72chevytrucks.com/vboard/s...ighlight=burbs 2003 Tahoe LT |
09-15-2015, 07:49 PM | #16 |
One foot in front of the other
Re: New shoes
Sharp
09-16-2015, 07:38 PM | #17 |
Re: New shoes
Yes Leon I used CPP parts, you changed out your shocks too? Not sure what the problem may be, you may have gotten the wrong parts, I did get a wrong bearing and two different size brake lines when I ordered.
09-28-2015, 05:10 PM | #18 |
Re: New shoes
Yes, I did put new shocks on it too.
