Old 06-10-2015, 08:35 AM   #1
canadian_diesel1964
Lower Ball joint issues...
hey guys I have a 63 C10 ..this morning I pressed out the lower Ball joint. I bought Old stock perfect circle Ball joints thinking i was ahead of the pack but they just drop in...I was thinking that to use my new 73-87 spindles I could just put in 73-87 Lower Ball joints and uppers...do the tie rod swap and be done...but...they just fall in...any idea where I failed?
canadian_diesel1964 is offline   Reply With Quote
Old 06-10-2015, 09:01 AM   #2
1963c-10
1963c-10's Avatar
Re: Lower Ball joint issues...
Were the original ball joints you removed still riveted in? Or were they bolted in?
1964 Short bed trailer
Old 06-10-2015, 09:04 AM   #3
canadian_diesel1964
This is the lower press in joint
Old 06-10-2015, 09:18 AM   #4
1963c-10
1963c-10's Avatar
Yeah.....sorry.......not enough coffee in the system yet. I'm thinking the uppers. I do know that if the bottoms have been replaced multiple times I have seen them just about fall out.
I have seen many that were tack welded in.
Old 06-10-2015, 09:22 AM   #5
canadian_diesel1964
I hear you on the coffee! The ones that were in were in nice and tight ...had to press em pretty good..I'm getting some moogs from car quests at noon to see
Old 06-10-2015, 09:29 AM   #6
Texas1963
Texas1963's Avatar
Replacing the uppers and lowers on mine today with Moogs. Will be grinding off the rivets on uppers and getting a loaner press for the lowers and hope all goes as planned.
Texas1963 is offline   Reply With Quote
Old 06-10-2015, 09:29 AM   #7
1963c-10
1963c-10's Avatar
You might have to go to an oversized ball joint to correct the issue. They should be a tight fit.
Old 06-10-2015, 09:47 AM   #8
TJ's Chevy
TJ's Chevy's Avatar
Used stock style moogs ball joints on my a-arms....upper ones were fairly easy coming out and going in but the bottom ones...sheesh! lol Sledge hammer to get those in. But they're tight.
Old 06-10-2015, 09:49 AM   #9
1966burb
1966burb's Avatar
You will want to rent the ball joint press from your local parts store. It will press the old ones out and also install the new ones. Made the job a breeze!!! J
1966burb is offline   Reply With Quote
Old 06-10-2015, 01:01 PM   #10
canadian_diesel1964
Thanx for all the replies guys...does anyone happen to know the part number for the oversized ball joint?
Old 06-10-2015, 12:49 PM   #11
canadian_diesel1964
The carquest joints were also too small ..I'm not sure what to do as I have drop spindles for a 73-87
Old 06-10-2015, 01:08 PM   #12
1963c-10
1963c-10's Avatar
This appears to be the oversized lower ball joint that Carquest shows since that's where you posted the last part coming from. I'd double check though just to be sure. It wouldn't let me punch in anything older than 1975, so I used 75 c-10 chevy 5.7l as the reference. #505-1021OS (oversized)
http://www.carquest.com/webapp/wcs/s...8682?acesApp=1
I also use Red Locktite on my lower ball joints. I've never tacked a set in personally, but have heard a lot of people who have and have seen quite a few done that way.
Old 06-10-2015, 01:14 PM   #13
canadian_diesel1964
That's perfect..thank you
Old 06-10-2015, 01:15 PM   #14
1963c-10
1963c-10's Avatar
No problem. You'll get it resolved in the long run.
Old 06-10-2015, 01:27 PM   #15
canadian_diesel1964
I was thinking I might tack them in...the guy at the parts store said the oversized one crosses to the ones I already bought....not sure if that's the computer talking or not
Old 06-10-2015, 01:35 PM   #16
1963c-10
1963c-10's Avatar
Carquest shows 505-1021 for the standard lower and 505-1021OS for the oversize. Whats the original part # that you got?
Old 06-10-2015, 01:46 PM   #17
canadian_diesel1964
He crossed to moog k6117T
Old 06-10-2015, 02:15 PM   #18
chevy_mike
Never Ending Projects
chevy_mike's Avatar
I ran into this decades ago where the oversized one were still not tight in the arm. It was suggested that I take the arms to a welder who could run a weld bead around the outer edge of the hole, which would cause the hole to shrink smaller. Sure enough it worked and never had a problem after that.
Just another idea to throw out there.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 06-10-2015, 02:32 PM   #19
canadian_diesel1964
Thank you...along the top?
Old 06-10-2015, 02:34 PM   #20
canadian_diesel1964
Found these but unsure on quality
Old 06-10-2015, 06:35 PM   #21
chevy_mike
chevy_mike's Avatar
No, the underside of the arm. Flip that over and the lip that the ball joint presses into, around the outside of that (not the area where the ball joint actually touches).
Old 06-10-2015, 07:08 PM   #22
canadian_diesel1964
I like that idea...I found oversized ball joints for 23 bucks each from classic industries. just so happens napa sells the same joint under the same part number....0025 oversized...if it gets me close ill lay a bead around that lip as you say..thank you for your help
Old 06-11-2015, 09:26 AM   #23
Pappyx3!
Pappyx3!'s Avatar
Moog web catalog says it should be a K6023. Moog tech support says the K6023 is part of their problem solver line. It is made OS to compensate for the wear in the lower control arms.
http://www.moog-suspension-parts.com...10_pickup_1963
Good Luck!
Pappyx4!
1962 Chevy C-10 Stepside 383 Stroker, Turbo 400
1966 Chevy C-10 Stepside 250 6Cyl, 3OTT- Daily Driver
John 3:16
Pappyx3! is offline   Reply With Quote
Old 06-11-2015, 09:44 AM   #24
Texas1963
Texas1963's Avatar
Good Luck!
Pappyx4!
Installed the Moog K6023 yesterday and all went well using the press from the parts store. I could not imagine doing it with out it. Gonna do the passenger side in the fall when it cools down.
Old 06-11-2015, 09:52 AM   #25
canadian_diesel1964
Which control arms are you guys using and which spindles will the k6023 fit? I am using the 63 control arm with 73-87 drop spindles...thank you!
